Double batterys - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 3Likes
post #1 of 15 (permalink) Old 06-16-2017, 09:20 PM Thread Starter
Buddy's Avatar
Double batterys
question . I have two Vulcan 750 a 1995 and a 1989. I would like to know would it be safe to install a second battery wired in parallel so I would double my ability to provide a stronger power to my starter or is it an issue to put to much additional strain on our bikes stators by doing this . With recent manufacture of iron phosphate batteries that are small and can easily be placed in saddle bags. Is this a doable solution for the poor electrical problem our bikes have or is it a bad move.
My bikes both start well but its the hot restart that gives me issues . When the bike is hot its hard to restart some times . Would appreciate some thoughts on my idea
!995 1989 VN750 Both bikes have identical accessories. Rear facing cameras with windshield mounted color monitors. Hard saddle bags. Tire pressure monitors. All recommended mods. Removable rear trunks with alarms. Ground facing LED Kawasaki logo illuminate with brake lights .
Buddy is offline
post #2 of 15 (permalink) Old 06-16-2017, 10:17 PM
do you have wet cell or AGM?
post #3 of 15 (permalink) Old 06-16-2017, 10:22 PM Thread Starter
Buddy's Avatar
One bike is agm the other bike is a shorai lithium iron phosphate, I just want to try and increase my power to start
Buddy is offline
post #4 of 15 (permalink) Old 06-17-2017, 08:20 AM
Check out the pickup coil mod; seems to fix it. I'm getting ready to do it to my bike this weekend.
Panic1982 is offline
post #5 of 15 (permalink) Old 06-17-2017, 09:16 AM
With a ago already, pickup coil mod should take care of it
post #6 of 15 (permalink) Old 06-17-2017, 11:41 AM
To answer your question.... You can run two batteries in your bike, but I'd advise against it. The other battery would put a strain on your charging system. They do make "battery isolators" that would prevent this, but unless you are running A LOT of other electrical accessories, I see no need.
Gaz73 likes this.
post #7 of 15 (permalink) Old 06-17-2017, 11:43 AM
Bad move.
If you are having trouble starting, address the issue, don't just band-aid it with trying to parallel up some batteries.
I third the pickup coil mod. Direct power to the coils did a ton of good.
Gaz73 likes this.
post #8 of 15 (permalink) Old 06-17-2017, 03:18 PM
NewB to Vulcans
TonyO's Avatar
Not a good idea to parallel batteries as each one will charge and discharge differently. Whichever is the most easily charged will be constantly overcharged and vice versa.
'99 Vulcan "Victoria"
TonyO is offline
post #9 of 15 (permalink) Old 06-17-2017, 05:04 PM
That's why I said you'd need a battery isolator....to prevent this exact thing.
I'm not sure even then if this would help. You'd need to rewire the bike so one. Battery only is used to start the bike, and the other powers all the lights and accessories. A lot of work for something you really don't need on a bike like the Vulcan. A Goldwing with a big stereo, heated seats, etc...be a good candidate... but you'd also have to make sure the charging system could handle the extra load. I think Harley Police bikes had two batteries.....
post #10 of 15 (permalink) Old 06-18-2017, 07:22 AM Thread Starter
Buddy's Avatar
I see all of your points. Well taken I guess I will try the coil mod. Thanks to all
Buddy is offline
