Where to hook up Volt Meter-??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 36 (permalink) Old 12-17-2008, 07:21 PM Thread Starter
I would like to hook a volt meter up to read only when the key is on,and would like to do it in the headlight cage if possible... Would the marker light wires work, or would the signal part give problems...??? Is there a better place to hook up..??
post #2 of 36 (permalink) Old 12-17-2008, 07:35 PM
OttawaGuy's Avatar
Just my 2 cents here. I have the Kury LED voltmeter mounted between the guages. I ran the wire to a lighted switch mounted on the right neck cover and then home runned it to the battery. I wanted the most accurate reading and I was not sure of tapping any of the bucket wires. Took me 20 min mostly because I soldered the connections.
I am sure someone else will chime in on tapping the bucket wires.
1995 VN 750A11 34,595 miles
Highway Hawk Coolant bottle cover
Slant Saddlebags
Kury Throttle Boss
Kury Brake Pedal Cover
Kury Shift Lever Cover
Kury LED Votlmeter
Uni Foam Air Filters
Dual Fiamm 120db horns
Plexstar II Fairing
Splines Lubed
Crash Bar/Engine guard
Highway pegs
Saddleman Classic Explorer Seat
Battery Tender Jr.
Show Chrome 7 in Headlight Visor
Fire and Steel Billet rear Shock Nut Covers
Clear Alternatives LED Brake Light
OttawaGuy is offline
post #3 of 36 (permalink) Old 12-17-2008, 07:39 PM
I suggest adding a relayed power source for it.... Power Block Relay
Wired up like this would leave it connected hot to the batt, but only when the key is on and sending power to the relay.
post #4 of 36 (permalink) Old 12-17-2008, 07:58 PM
I used the spare hot wire in the headlight bucket, it worked fine with Kury volymeter.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #5 of 36 (permalink) Old 12-17-2008, 11:22 PM
Isn't that lead always hot? I know the leads under the side cover are always hot.
post #6 of 36 (permalink) Old 12-18-2008, 08:04 AM
yes the spare wire is hot. you can splice into the front running lights but you will get a drop in actual voltage. i will hook mine up to the batery with the use of a relay and inline fuse for a true reading. its a bit more work but that is what i want
dutter is offline
post #7 of 36 (permalink) Old 12-18-2008, 08:29 AM
slim, thanks for the link. good article, it would save adding a relay for every hook up
dutter is offline
post #8 of 36 (permalink) Old 12-19-2008, 12:11 AM
t-rider
Slim..glad you posted that...where would be the best place to attach the power block and relay....
91 VN750
R/R RELOCATED
COASTERED
VOLTMETER
SPLINES LUBED
EAR SHAVE
REAR TURN SIGNALS RELO
BIG CRANK AGM
prew is offline
post #9 of 36 (permalink) Old 12-19-2008, 02:09 AM
don't know if it is the best place...but since I relocated the R/R I placed mine where the R/R used to be under the battery box... another good place would be on the rear side of the battery box....or any place you can find.... I have heard of people using the tool box as well... I think the Tool box would be one of the best locations.
post #10 of 36 (permalink) Old 12-19-2008, 11:41 AM
t-rider
Thanks...............
91 VN750
R/R RELOCATED
COASTERED
VOLTMETER
SPLINES LUBED
EAR SHAVE
BIG CRANK AGM
prew is offline
