How to track down a short? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 25 (permalink) Old 05-05-2017, 09:51 PM Thread Starter
Let's Ride!!
DaveT319's Avatar
Last year, I had a situation where I was riding my bike and all of a sudden lost power. Bike died, and no electrical power. Tried recharging the battery, but it wouldn't take a charge. Bought a new one, charged it up, installed it, and everything seemed fine.
Bike sat for about a month, not hooked up to a battery tender (I've left it for much longer than that in the past and not had a problem). Went to turn on the bike: no power. Hooked it up to my battery tender. The next day, still wasn't charged. Checked the battery: 3 volts. Took it to Autozone, they said the battery wouldn't take a charge again.
I've now got another battery, but I don't want to hook it up until I can figure out what's going on. It seems to me that I have a short somewhere that is draining the batteries. So how would I go about tracking it down, short of testing every single wire and connection on the bike? Or is that the way I have to do it? I simply still don't know enough to know how to proceed.
DaveT319 is offline
post #2 of 25 (permalink) Old 05-06-2017, 12:20 PM
Use a test light or meter between the battery positive post and the positive battery cable, with cable loose. If there's a current draw with the key off, start removing fuses until the draw stops. The fuse that kills the draw is on the circuit causing the problem. That would at least narrow the search. Always a possibility the draw will not be affected by fuses, but this a place to start.
Lacking a test light or meter, you can touch the loose battery cable to the battery and watch for a tiny spark. Beware if there's any out-gassing if the battery has just been removed from a charger. The gas is explosive, if you smell rotten eggs near the battery, that's explosive hydrogen sulfide gas.
edit - Try unplugging the R/R first and see if that kills the draw. That's the most common place on this bike for a current draw problem.
post #3 of 25 (permalink) Old 05-14-2017, 05:46 PM Thread Starter
Let's Ride!!
DaveT319's Avatar
This is frustrating.
I pulled the fuses, and was still getting a draw, until I pulled the main fuse. Damn. Then I pulled the R/R, and that also killed the draw. Double damn, cuz I just replaced what I thought was a faulty R/R. So that means the R/R I just bought less than a year ago is bad!
Guess I'll be getting yet another one. Lame.
DaveT319 is offline
post #4 of 25 (permalink) Old 05-14-2017, 07:59 PM
check the connector on the r and r
post #5 of 25 (permalink) Old 05-14-2017, 08:32 PM Thread Starter
Let's Ride!!
DaveT319's Avatar
Yeah, I will.
Doesn't dielectric grease conduct? Cuz I smeared it all over the connectors, and am wondering if I created a short that way by using too much.
DaveT319 is offline
post #6 of 25 (permalink) Old 05-14-2017, 09:28 PM
ubertalldude's Avatar
Nope, that's the beauty (and point, really) of dielectric grease, it doesn't conduct but seals out moisture nicely.
Did you replace with a stock R/R or are you a MosFet/Series convert?
ubertalldude is offline
post #7 of 25 (permalink) Old 05-14-2017, 09:36 PM Thread Starter
Let's Ride!!
DaveT319's Avatar
Stock one off eBay. Didn't want to have to do a bunch of rewiring.
DaveT319 is offline
post #8 of 25 (permalink) Old 05-14-2017, 10:44 PM
could be bad r&r if you bought a used one.was asking about the connector cause that's a common issue on these bikes
post #9 of 25 (permalink) Old 05-14-2017, 10:59 PM Thread Starter
Let's Ride!!
DaveT319's Avatar
No, it was supposedly new.
What's the issue with the connector? What can be done to fix it?
DaveT319 is offline
post #10 of 25 (permalink) Old 05-15-2017, 12:25 AM Thread Starter
Let's Ride!!
DaveT319's Avatar
And can someone remind me of how to test the R/R to make sure it's working right? slimvulcanrider used to have a thread with changing system test info, but he seems to have erased the first post for some reason. Had all the multimeter tests and expected numbers.
DaveT319 is offline
