Aftermarket License Plate w/ Blinkers - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 3Likes
  • 1 Post By Spockster
  • 2 Post By Spockster
post #1 of 7 (permalink) Old 04-18-2017, 02:52 PM Thread Starter
So I'm trying to slim my '05 750 down as much as possible and I bought a license plate cover with blinkers built in on the sides without thinking about it too much.After reading about the turn signals, they have 3 wires per signal. From the pictures it looks like this license plate has only 1 wire running from each signal. Do I have any options now? Thanks
MikeIronTyson is offline
post #2 of 7 (permalink) Old 04-18-2017, 02:58 PM
3 wires is for the following.
Ground, running light, blinker.
The new blinkers should have at least 2 wires, ground and blinker.
post #3 of 7 (permalink) Old 04-18-2017, 04:06 PM
Factory rear signals are turn signal only, so no running lights.
The single wire lights most likely just ground through the mounting. So they either need metal contact to the bike, or a jumper wire to ground.
MikeIronTyson likes this.
post #4 of 7 (permalink) Old 04-18-2017, 04:17 PM Thread Starter
The license plate itself is metal, which will ground with the bikes license plate holder I suppose? Then from there I suppose I just connect the single wire to the blinker wire and running&ground are left alone?
post #5 of 7 (permalink) Old 04-18-2017, 04:42 PM
If it's all metal, it should ground at the mount. Then you just need the right/left signal wires extended down to the plate.
My signals are mounted on the plate, three wire lights. Just extended the wires down through the fender.
thtanner and MikeIronTyson like this.
post #6 of 7 (permalink) Old 04-18-2017, 10:22 PM Thread Starter
Thank you sir.
post #7 of 7 (permalink) Old 04-19-2017, 10:37 AM
pic?
Tags
aftermarket , blinker , electrical , signals
