Headlight out: Bulb and Fuse are good... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 92 (permalink) Old 12-05-2008, 06:55 PM Thread Starter
Kawasaki_Kev's Avatar
First - I have looked through the vulcan verses etc and really haven't been able to put anything together, so I figured I would try a new thread.
My headlight went out.
Both high beam and low beam went out at the same time.
Both my bulb (even bought a new one to make sure) and the headlight fuse are good (even put a different known good fuse in).
I read about a headlight relay but am still not sure where it is located and if it can be replaced.
I also read about bypassing the relay so that when you turn the key the light stays on. Can anyone explain how to do this step by step or point me to a verse or thread that explains it clearly?
If need be I will do the bypass thing while I try to bug the problem out.
At least I can ride it
Kawasaki_Kev is offline
post #2 of 92 (permalink) Old 12-05-2008, 08:21 PM
Quiet rider
greyhound's Avatar
I just went through the exact same problem. Before you do anything else try this:
With the bike running, with your fingernail, flick the starter button a few times to see if the light comes on (i.e., partially push the button in with you nail and then let it slid off you nail and SNAP back). Obviously, be careful not to press the button in too far while it's running or the starter will engage the engine. Contacts in the start button assembly apparently (I'm no expert but am quite sure) disconnect the light while engaging the starter so that more current flows to the start circuit. When they get dirty or wear, the circuit sometimes does not re-engage when you release the start button and the light stays off.
I haven't yet fussed with mine enough to know if it can be fixed via electronic cleaner spray or if replacement will be needed but that's where the problem is on mine.
Good luck!
Greyhound
01 VN750
36k miles
No one on their deathbed ever said "I wish I had spent more time at work".
greyhound is offline
post #3 of 92 (permalink) Old 12-05-2008, 08:35 PM
Might try checking your ground on the battery and the wire going to your hlight.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #4 of 92 (permalink) Old 12-05-2008, 08:49 PM Thread Starter
headlight realy (proper name - reserve lighting switch)
OK - I found the headlight relay (proper name - reserve lighting switch) under the right side cover. Also - it can be replaced, but isn't cheap when purchased new.
post #5 of 92 (permalink) Old 12-05-2008, 09:09 PM
Mine has been by-passed since I have had the bike. I haven't had any problems.
post #6 of 92 (permalink) Old 12-05-2008, 10:20 PM
mines bypassed with manual switch hidden in left ear...cheaper than the 100$ junction box
googy00 is offline
post #7 of 92 (permalink) Old 12-06-2008, 02:22 AM
sounds to me like the relay inside the junctionbox is fried man.... check to see if you can get the headlight on by jumping pin 7 and pin 8 on the JB...If headlight turns on then the relay inside the JB is bad....this happened to me when I purchased my bike...there are two fixes for this...the easiest fix is a new JB...the second fix is soldering in a relay off of another toasted JB.
Also the Reserve Lighting Unit is NOT the relay...check out the Junction Box wiring Schematic in the Repair Manual. PG 289 in the PDF manual, or PG 15-50 in the Clymer's Manual. also if you need more comprehensive diagrams, I have all of them as color JEPEGS.
post #8 of 92 (permalink) Old 12-06-2008, 08:42 AM Thread Starter
How do I bypass the relay?
If nothing it might keep me going for now - bikes down
Have to have a headlight on at all time in Florida...
post #9 of 92 (permalink) Old 12-06-2008, 11:00 AM Thread Starter
Well - I tried jumping pin 7 and 8, at least the best I could, but the headlight did not come on. I say the best I could because the diagram I have in my clymer shows the 8 pin connector having all 8 spots taken up. My 8 pin connector is missing either the 1 or 7 (depending on if your looking at the front or back of connector). I will be looking into to this further, but if anyone else has come across this feel free to enlighten me
Hey SlimVulcanRider, I'll take you up on the diagrams you have if you thank they may help. Either way, I appreciate the help and willingness to share your diagrams.
I also flicked the starter button a couple of times and the headlight came on. However, I have noticed that the back running lights (left/right turn signals) are not working even when I get the head light on. The turn signals work when used, but not as running lights. Again the fuse is good for these also.
post #10 of 92 (permalink) Old 12-06-2008, 11:18 AM
Well, I would think the headlight coming on when flicking the starter button is a good sign.
But remember, the rear turnsignals are not running lights, like the front ones are. They are only turnsignals, so they shouldn't be on when the headlight is.
