volt guage - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 37 (permalink) Old 12-04-2008, 03:06 PM Thread Starter
volt guage
my next project will be installing a volt meter. i was wondering if you all tapped off an existing "keyed" circuit or if you put the meter on its own circuit off the batery with a relay?
dutter is offline
post #2 of 37 (permalink) Old 12-04-2008, 03:14 PM
Chucklehead
dragon159's Avatar
I tapped into the front running light circuit, bu then it's only temporary until the front end goes back together. Then I'll find a place to tap into the fuse box if at all possible.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #3 of 37 (permalink) Old 12-04-2008, 04:29 PM
I would tap into the y/r wire coming out of pin 13 on the JB it is tied directly into the alternator and battery with a relay and a fuse. check out pg 15-36 of the Clymer Manual.
post #4 of 37 (permalink) Old 12-04-2008, 07:22 PM
Mines wired directly to the battery (fused of course) with a relay to turn it on & off, lead from the junction box. I have a diagram for the basic wiring on my post as well. There's deffinatly several ways to wire it up.
To Each There Own & To Own A Good Night. =)
post #5 of 37 (permalink) Old 12-04-2008, 11:27 PM
t-rider
Wired mine to the front running and signal wires in the headlight bucket...works well..if someone reads this and thinks I might do damage please let me know....
91 VN750
R/R RELOCATED
COASTERED
VOLTMETER
SPLINES LUBED
EAR SHAVE
REAR TURN SIGNALS RELO
BIG CRANK AGM
prew is offline
post #6 of 37 (permalink) Old 12-04-2008, 11:37 PM
The Professor
lance328's Avatar
It won't do any damage but your reading will be lower than if you connect to the battery w/inline fuse and a relay switched from a key on circut.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 37 (permalink) Old 12-05-2008, 12:00 AM
t-rider
Thanks Lance328 I'll have to read up on how to do that....
91 VN750
R/R RELOCATED
COASTERED
VOLTMETER
SPLINES LUBED
EAR SHAVE
BIG CRANK AGM
prew is offline
post #8 of 37 (permalink) Old 12-05-2008, 08:17 AM Thread Starter
thanks guys, im thinking about slims idea to save from buying and installing a relay. i was wondering if that circuit would give a true reading from the battery or is there draw that would lower the guage reading? if no one can give me an answer i will test it myself. thanks again
dutter is offline
post #9 of 37 (permalink) Old 12-05-2008, 08:26 AM
I had it wired both ways. I didn't really notice any differance other than the peice of mind knowing I was monitoring the battery opposed to a circuit on the bike. I know, splitting hairs right. The head light bucket hook up is deffinatly the easier of the two.
Here's a link to what I went through.
post #10 of 37 (permalink) Old 12-05-2008, 01:31 PM
t-rider
I'm low on electrical knowhow..what kind of relay and size fuse for the voltmeter and where do you get it. I saw your diagram.
91 VN750
R/R RELOCATED
COASTERED
VOLTMETER
SPLINES LUBED
EAR SHAVE
BIG CRANK AGM
prew is offline
