starter failed how to get out - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By Spockster
post #1 of 7 (permalink) Old 04-13-2017, 11:43 AM Thread Starter
the starter on my 1992 kawasaki vulcan 750 isnt working found a new one but how do you remove the thing the two bolts on the back and then does it just pull out of there or is there a bigger gear on the starter gear that has to come off first
Josh Hamman is offline
post #2 of 7 (permalink) Old 04-13-2017, 01:01 PM
nope, will pull right out.
michiganteddybear is offline
post #3 of 7 (permalink) Old 04-13-2017, 02:05 PM
Drain the oil first.
Thorn likes this.
post #4 of 7 (permalink) Old 04-13-2017, 03:33 PM
good point.
if its a little hard to get moving, there is an o-ring or 2 on the snout for oil seal, they may be stucky
post #5 of 7 (permalink) Old 04-13-2017, 04:48 PM
Wink
Originally Posted by michiganteddybear View Post
good point.
Didn't sound like Josh was using a repair manual, so I thought that might prevent a huge mess wherever he's working.
Get to pull my starter off soon, pretty sure it's that o-ring leaking oil. Need to find an o-ring first.
post #6 of 7 (permalink) Old 04-13-2017, 05:01 PM
vulkan's Avatar
Go buy an assortment of "O" rings....they cheap!!
vulkan is offline
post #7 of 7 (permalink) Old 04-13-2017, 05:20 PM
Was going to hit Harbor Freight and see if I can find some, need a tiny one for Honda carb, and a coolant tube has been seeping on the VN, that o-ring is only a couple of years old.
I guess that o-ring on the starter must be close to 1" to 1.25"... 22-25mm?
