need help bad - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 11-28-2008, 03:52 PM Thread Starter
need help bad
my vulcan 750 is an 89 model a-5 last night i parked it on some soft ground and the bike slowly fell over the kickstand sunk in the dirt it did not damage anything that i can see but i tried to start it and it would not start at all,i noticed the switch on the kickstand was bent a lil could this be the problem? if so how can i fix it or can i bypass it? all my lights come on its just no fire to start it please help!
whiteboy is offline
post #2 of 10 (permalink) Old 11-28-2008, 05:57 PM
Vintage bike addict
antiq's Avatar
By any chance did you move the kill switch picking it up? Did you try starting it with the sidestand up? Is there any damage to the clutch switch? Have you removed the left sidecover to see if any electrics got wet or out of place? Does your bike have a maintenance free battery? I think more info is needed here.Was it in neutral?
Eleanor Roosevelt.
antiq is offline
post #3 of 10 (permalink) Old 11-28-2008, 08:27 PM
This thread is posted on the general discussion forum too. antiq gets to the heart of the matter a lot quicker than I did though.
post #4 of 10 (permalink) Old 11-28-2008, 08:56 PM Thread Starter
no problems with clutch switch,yes tried to start it with stand up,no mfb,electrics ok
whiteboy is offline
post #5 of 10 (permalink) Old 11-28-2008, 10:54 PM
By "no fire to start", do you mean it's not even trying to turn over, or it turns over and over and over, just doesn't start?
post #6 of 10 (permalink) Old 11-29-2008, 01:31 AM
if you read his other post he says it won't even turn over
post #7 of 10 (permalink) Old 12-17-2008, 10:25 PM
58D IP/SP
kruser's Avatar
If any fuel leeked into the intakes or filled the carbs it will only click one time as you try and start it. keep it upright for a couple of hours and take of the intakes if you can. this will let the gas that's in there evaporate. Try it again, if that didn't work I'm out of suggestions unless your battery went belly up and leaked all the water out while on it's side.
OUTCAST 22 OUT!
05 VN750
16,000 miles+
Garmin 2610 GPS
J&M Radio WX & CB, XM Radio
2 1/2 gal Aux Tank = 250 Miles
ATV Seat Cover from WalMart
Joe Rocket Tank Bag, Saddle Bags, Leather T Bag
So Many Toys, So Little Time!
If You Can't Carry It, You Don't Need It!
kruser is offline
post #8 of 10 (permalink) Old 12-17-2008, 10:26 PM
58D IP/SP
kruser's Avatar
When I was installing my Aux tank I had fuel overload issues. I had gas running out the intakes. The bike would only click once untill I let everything dry out. Not sure how it knows but it does...strings and mirrors I think.
OUTCAST 22 OUT!
05 VN750
16,000 miles+
Garmin 2610 GPS
kruser is offline
post #9 of 10 (permalink) Old 12-18-2008, 12:50 PM
Undercover Sportbiker
AJCruzin's Avatar
Assuming you have power - you do have power, yes? Try holding in the kickstand switch and thumbing the starter. If it's bent as you said, it could be bent just enough to prevent it from working properly.
AJCruzin is offline
post #10 of 10 (permalink) Old 12-18-2008, 01:55 PM
Vintage bike addict
antiq's Avatar
It's been almost a month. Any luck getting it going?
Eleanor Roosevelt.
antiq is offline
