splicing in a fused volt meter for actual voltage post ignition switch - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 5Likes
post #11 of 19 (permalink) Old 04-02-2017, 01:55 AM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
No such blue wire mod here. Gidaeon, are your questions answered? Mine are.
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Progressive 412 shocks
Chris and Shim is offline
post #12 of 19 (permalink) Old 04-02-2017, 04:48 PM Thread Starter
All set. I went with direct to battery for now (existing cig lighter already routed in place).
Gaz73 likes this.
gidaeon is offline
post #13 of 19 (permalink) Old 04-02-2017, 09:02 PM
If your voltmeter is connected direct to the battery...
1. It won't be fused unless you install an inline fuse yourself.
2. If you don't have a switch to turn it off, it will drain your battery. The one I used only used 0.05ma ...which isn't enough to drain your battery unless you don't run the bike for 8 weeks. Back lit voltmeters use more power.
3. If you do install a switch...the odds of you forgetting to turn it off may be an issue.
4. Many wire their voltmeter to the front running lights...these turn of with the ignition switch and save the money and time needed to wire in a relay. You can of course wire direct to the battery but trigger the relay off the running lights.
5. I do suggest using a fuse if you're not using a fused circuit.
roadpouring likes this.
post #14 of 19 (permalink) Old 04-04-2017, 10:00 AM
gidaen's meter came with a fuse and a switch built in.
post #15 of 19 (permalink) Old 08-29-2017, 10:12 PM
Has anyone seen this?
https://www.amazon.com/MICTUNING-Cha...+voltmeter#Ask
Looks pretty sweet and saves a step when adding usb and voltmeter. I saw one version where someone wired a usb port where the neck reflector used to be. That could work cool for this if it's deep enough. (I think it's deeper on the left side of the bike that the right side.)
Thoughts? Concerns?
LandyLou is offline
post #16 of 19 (permalink) Old 08-29-2017, 11:46 PM
looks cool
OleDirtyDoc is online now
post #17 of 19 (permalink) Old 07-06-2018, 02:18 AM
Finally getting around to this project. I like your idea wiring the USB/voltmeter through the running lights to have it turn off with the ignition. I see on the wiring diagram that the signals have blue, gray, and black/yellow wires. Any idea which one is the running lights?
LandyLou is offline
post #18 of 19 (permalink) Old 07-06-2018, 09:16 AM
Your Blue wire at the front turn signals has voltage when the ignition is on. Black/Yellow is the ground.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #19 of 19 (permalink) Old 07-06-2018, 09:48 AM
Thanks! I rewired the whole rear end, but it worked on the first try, so no need to go get a voltmeter
Thorn likes this.
LandyLou is offline
