F-Up Tux Mod. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 03-28-2017, 03:19 PM Thread Starter
Know-It-All White-Trash
F-Up Tux Mod.
If said person does not pay careful attention to youtube videos and needs to replace the stock (behind cover) stator mount section of the engine to re-grind a tux mod, what and where does said person find one or what is it called for search engines?
(ADHD here and a retired Lockhheed engineer friend is on board to help me catch details round 2)
BTW most folx can follow detailed instructions, dont let this post scare you away from a tux mod. but a re-grind is cheaper then an engine drop and replace i hope.
also, instead of the rubber grommet, im experimenting with the thick gasket gum comes in caulk tubes at AZone. put some inside the heat-shrink too but my engine is black.
"Spock2.2" 3 clutches,3 engines, FK TUX MOD! Clubman bars w/ trimmed lines, Progressive shocks, FLO filter, gages app, RAM mount, custom light and signals. UV lights(antifreeze box and socks glow),(Jetted) V&H pipes, Brisk 360, Kuryaken HWY pegs (leg indifference disability), Viking bags, wet ears, Oil temp cap, Mosffet r/r under saddle bag. [email protected] 530ft 1/2 throttle 5th gear. i am alive because they see me, they hear me! I can downshift as fast as I can get the hell outta the way!
Damon FTW is offline
post #2 of 4 (permalink) Old 03-28-2017, 04:23 PM
https://www.youtube.com/user/andrewdroth
this is Roach's youtube channel.. somewhere in there (I dont know which video number), will be the instructions your looking for.
michiganteddybear is offline
post #3 of 4 (permalink) Old 03-29-2017, 01:41 PM
Alpha Geek
Hexadecimus's Avatar
Kawasaki Motorcycle Parts 1994 VN750-A10 Vulcan 750 ENGINE COVER(S) Diagram
$129.62 new from Partzilla
14031 COVER, GENERATOR 14031-1187
I couldn't find any on eBay, but it's the worst time of year to find cheap parts. Someone probably has a junked engine you could get parts from.
Hexadecimus is offline
post #4 of 4 (permalink) Old 03-29-2017, 01:42 PM
Alpha Geek
You have to create an account to see the extended part numbers, but I use that all the time to find part numbers/names.
