good ride ended with no power - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 15 (permalink) Old 03-17-2017, 12:51 PM Thread Starter
Question good ride ended with no power
went for a ride on my 97 vn750 and on the way home it died no power to the key or past that point bike is right from dealer never had anything done to it
carl1968 is offline
post #2 of 15 (permalink) Old 03-17-2017, 01:01 PM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
Zero electrical anything? I myself have had no experience whatsoever with the fuses on this bike. Such a sudden death sounds like a fuse to me but someone will be along in a bit to render a more knowledgeable reply. I get the impression that it'll wind up being something more of an irritation than a big deal. Lets hope I'm right and its not the stator. Good luck to ya.
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Chris and Shim is offline
post #3 of 15 (permalink) Old 03-17-2017, 02:37 PM
Check battery voltage first, then fuses. Could have stopped charging, blown a fuse, or the switch is dirty/defective.
post #4 of 15 (permalink) Old 03-18-2017, 11:22 AM Thread Starter
blown fuse changed still no power when i turn key on
carl1968 is offline
post #5 of 15 (permalink) Old 03-18-2017, 11:34 AM
check the wires under the speedo...could be a wire broke from the weld..that would explain the fuse blown if shorted out. I had a very similar experience with my 98..and that was the fix method..maybe worth a look
jgs000 likes this.
Brooklyn_Vulcan is offline
post #6 of 15 (permalink) Old 03-18-2017, 12:01 PM
Also check the plugs under the left neck cover.
Turn the switch to the 'park' position, see if you get any lights.
post #7 of 15 (permalink) Old 03-18-2017, 03:45 PM Thread Starter
bike killed battery over night
carl1968 is offline
post #8 of 15 (permalink) Old 03-18-2017, 04:26 PM
probably have a short
post #9 of 15 (permalink) Old 03-18-2017, 04:41 PM Thread Starter
still no power at ignition switch turn key to park and still no lights battery on charger when it lost power it blow 30 amp fuse
carl1968 is offline
post #10 of 15 (permalink) Old 03-18-2017, 11:21 PM
Just a regular guy
Chris32250's Avatar
there is an infamous wire in the headlight assembly that gets crimped and shorts... it's brown if i remember correctly... I had the same issue years ago. look in the headlight for frayed or broken wires
"Pain is weakness leaving my mouth! *&%^$ that hurt!"
Promo code for 10% off at leatherup.com..... 55634
===2001 Vn750====
New Chrome agm battery
Ears shaved
Sportster pipes
12v adapter installed
Chris32250 is offline
