Bike dies when jumper cables disconnected - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 02-27-2017, 08:43 PM Thread Starter
Hey guys i got my new (1992) bike running after cleaning the carbs and using a different take to fuel it once it was running i disconnected the jumper cable and it immediately died. Restarted it using jumper cables and let it run for a while then tried again to disconnect and it would idle (sort of ) and the lights would get bright then dim ,and repeat as it idles then tried to give it gas and it died again. So I came inside and did a search to see if the bike should run with no battery and the answer i found seems to be yes.
So I know I need a new battery and I can't really test the charge output until I do so but my question is do you think my stator or something else is bad or should a new battery just fix this all?
dc4114dc is offline
post #2 of 5 (permalink) Old 02-27-2017, 09:09 PM
If it's running while on jumper cables you can probably still check the voltage output to the battery. Just make sure the vehicle you're jumping it from is turned off. You should be getting 14+ volts at 3-5k rpm's. If not then you have problems.
post #3 of 5 (permalink) Old 02-27-2017, 09:16 PM Thread Starter
I thought of that after I put the bike away and went inside and it's supposed to rain here the next two days. So I can't really recheck until later on. But once it's running shouldnt the bike stay running dead battery or not?
Sent from my SCH-I545 using Tapatalk
dc4114dc is offline
post #4 of 5 (permalink) Old 02-27-2017, 11:24 PM
cglennon's Avatar
The answer is NO. The electrical system on these bikes (and may others) is primitive and will not run without a good battery installed (or jumped as you have here). Remove the good battery or jumped one (surrogate battery) and the bike will die. Some big touring bikes, such as the Honda Goldwing, will run without a battery, but not the VN750.
Chris Glennon - Portland, OR
cglennon is offline
post #5 of 5 (permalink) Old 02-28-2017, 12:15 AM Thread Starter
This is good news for me, Hopefully it means that my electrical system may be just fine guess i'll test the stator and regulator after I get a battery instead of jumping to conclusions. Thanks for the help!
dc4114dc is offline
