DEAD Battery What the??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 10-26-2008, 11:47 PM Thread Starter
dirtrack650's Avatar
So my daughter and I went on an evening ride Saturday with all systems normal. Went to start it Sunday and the nice expensive MF battery is dead.
Volt meter read 13+ volts so I'm guessing the charging system was working.
Any ideas folks? I didn't get a chance to look at it today because I took out my GL500 on a beautiful fall ride.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #2 of 15 (permalink) Old 10-27-2008, 05:10 AM
YOU have 13 volts at the battery??? If I am reading that right, then i would say check into loose connections, and bad grounds....
post #3 of 15 (permalink) Old 10-27-2008, 06:40 AM
X2
Sounds like something loose, somewhere.
post #4 of 15 (permalink) Old 10-27-2008, 07:07 AM
Crobins365's Avatar
X3 13 volts is more than enough to get you going.
C
Crobins365 is offline
post #5 of 15 (permalink) Old 10-27-2008, 07:14 AM
ryn
I think they meant while riding thet were getting at least 13 volts. but even so a loose connection somewhere is a good suspect. i have a fan that runs off a switch for now. that will kill a battery quick. maybe some accessories are to blame
ryn is offline
post #6 of 15 (permalink) Old 10-27-2008, 07:45 AM
750Doug's Avatar
I agree. I read that sentence and thought it to mean that during the ride just before the break-down his mounted volt meter showed all was well, and I know he knows his way around his bike.
A connection; loose, corroded, melting, or a combination of...
Interesting we all look at the same post, but read something a little different.
Guess we wait for DT to return and clarify.
750Doug is offline
post #7 of 15 (permalink) Old 10-27-2008, 08:02 AM Thread Starter
13 + volts when riding the day before, and when I first turned the key on to start the next day the volts were 12.5 (I check every time before starting). When I kicked in the starter, the volts dropped, the relay clicked and the lights dimmed. The volt gauge dropped below 8 with the running lights barely visible.
I did get a chance to plug in a trickle charger - that showed full charge - but do you all think the battery is bad? My brother said a battery can have volts but not enough amps to start. It's not a year old so if I get a chance today, I'm taking it to SEARS for a load test.
My charger connects via pigtails behind the left side cover so I didn't check for loose connections.
Thanks all,
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #8 of 15 (permalink) Old 10-27-2008, 08:17 AM
Crobins365's Avatar
12.5v is almost normal, but a little on the low side (I've got a battery that's been slowly dropping - used to be 12.8/12.9, and now is 12.5 - 12.7v; definitely needs to be replaced). When you were riding, did the voltmeter ever get above 14v or did it always stay below that (13v+ but less than 14v)? If so, I'd be looking at the connections first, and then have the battery load-tested. As ryn has experienced with his charging system, 13.9 isn't quite enough to do the job.
C
post #9 of 15 (permalink) Old 10-27-2008, 08:37 AM
750Doug's Avatar
Yes, this is possible. Just experienced the same thing on my brothers bike. Volt meter showed enough volts to do the job, but then a load tester showed otherwise.
Ditto.
750Doug is offline
post #10 of 15 (permalink) Old 10-27-2008, 09:50 AM
I have been having similar probs with my bike not starting...traced it back to a loose ground, and a loose connection on the starter relay.
