Smoking wires / won't start - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 14 (permalink) Old 10-20-2016, 07:08 PM Thread Starter
ClimbBikeBrett's Avatar
Hello everyone,
Last night I was driving home from work and stopped at the liquor store for a 6 pack. I wasn't in the store for more than 5 minutes and when I attempted to start the bike i got a hint of it turning over and then lots of clicking. I waited about ten minutes and tried again (thinking that it may be some hot start issue) and same thing happened except this time I could smell burning plastic or wires. It was dark and so I walked it the 1/4 mile back to my apartment. This morning I tried to start it again and this time I could see smoke coming from the wiring harness. I've attached a picture to show where the heat is burning through the electrical tape. I looked at the battery terminals and noticed that the metal piece that connects the negative lead to the frame (I'm guessing to ground?) had broken. Could that be causing a short and the wiring system to overheat? Also, what part number is that? I will order it from bike bandit. I already purchased a new (used) wiring harness from a 2004 that is in good condition to replace the old one. Could there be another issue causing wires to melt? The battery, stator, and regulator were all replaced about 5,000 miles ago. The regulator has not been relocated yet, though. Any help is greatly appreciated!!
ID:	34610   Click image for larger version
ClimbBikeBrett is offline
post #2 of 14 (permalink) Old 10-20-2016, 07:17 PM
A faulty ground can cause all sorts of hub-bub, but a short like that makes me think something rubbed through the insulation and touched the frame. Once that happened, fireworks!
post #3 of 14 (permalink) Old 10-20-2016, 08:42 PM
without a proper ground (the cable that broke), then you will get all sorts of weird shiat happening.
fix the ground, and cross fingers, it may just start up and work. After all, everything but the starter is fused, so you should be 'safe'
but I would definately look at the wires there where it started to cook and double check them
post #4 of 14 (permalink) Old 10-20-2016, 09:15 PM
yup that ground,when broken,positively charges the gas tank sender,causing it to short out.been there with mine.
post #5 of 14 (permalink) Old 10-20-2016, 10:04 PM Thread Starter
Cool. Do you guys know what piece that is that broke? I'm looking at the schematics and can't seem to figure out what it is.
post #6 of 14 (permalink) Old 10-21-2016, 12:43 AM
That's a pretty impressive insulation cutter you've got yourself there.
Can't find a part number for it, but:
86 KAWASAKI VN750 VN 750 VULCAN BATTERY CABLES #18 | eBay
There are several postings for battery cables that would NOT work too.
Seems like it might be easiest to just hit up the local auto parts store and get a new heavy-duty eye connector that you could replace the broken metal with.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #7 of 14 (permalink) Old 10-21-2016, 01:25 AM Thread Starter
So it's called an eye connector! Alright, I'm getting closer to figuring this out. Thank you very much for the link. I'll head to the dealer tomorrow and if they don't have the connector I will purchase the one on ebay. You guys are amazing! Thank you! Btw, even though this machine is old and cranky I wouldn't have chosen a different bike! Love it!
post #8 of 14 (permalink) Old 10-21-2016, 01:39 AM
You can make your own ground cables or buy them pre-made as well at local auto stores. The little black/yellow cable just needs to be grounded, as well. You can crimp on an eyelet to it and put it direct on the negative post along with the main ground.
post #9 of 14 (permalink) Old 10-21-2016, 09:09 AM
should have that ground in the wiring harness ya bought
post #10 of 14 (permalink) Old 10-21-2016, 03:56 PM Thread Starter
Doc, you are probably right! It is in the mail, so we shall see on Monday. I bought the wires and eye rings that I need to make a new ones and I'll do that at some point this weekend. It would be cool to get it running again, so that I can hold off on putting in the new wiring harness until next weekend.
