Signals Pulling to much Load. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 10-14-2008, 01:42 PM Thread Starter
Question Signals Pulling to much Load.
Well the title says it all. I'm not sure what else to concider. I've checked the connections & can't find a short. I can litteraly watch the meter drop every time the signal flashes. Left, Right & 4way. Any Ideas? Thanks.
post #2 of 5 (permalink) Old 10-14-2008, 05:47 PM
Have you changed or added anything else to the bike recently?
You could try unpluging one signal at a time and then turning the switch on to see if you can isolate which one it might be.
Have you checked/ cleaned the switch contacts?
What about the flasher unit itself. Just checked Clymer manual but didn`t find anything. Do the signals and 4-ways run off the same flasher?
Did the bike get wet before this problem started?
Is the battery itself intact? No breaks in case, etc.
I HATE ELECTRICAL PROBLEMS!!! Good Luck
post #3 of 5 (permalink) Old 10-14-2008, 06:26 PM
Chucklehead
dragon159's Avatar
Another thing to check is the bulbs themselves, and corresponding sockets for corrosion. A little dielectric grease would help. But I would almost guess that there is an odd bulb at work here.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #4 of 5 (permalink) Old 10-14-2008, 07:03 PM
HAWK
Ccspinner's Avatar
Have you done a volt test on the system or a amp test on the turn circuit?
that is where I would start.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #5 of 5 (permalink) Old 10-14-2008, 08:11 PM Thread Starter
I have a "meter" but not exactly the knowhow. I understand really basic wiring stuff. I'll need a boost for the checking bit.
I was fishing for ideas to what I missed.
