Which Wire for driving lights. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 10-13-2008, 10:47 AM Thread Starter
basherbob's Avatar
I want to clamp a pair of low amp (20each) driving lights on the engine case crash bar of my 1995 vn750 for visibility but not sure which accessory wire to use.
I have been reading a lot about the 'wonderful' electrical system on these bikes and want to use a switched circuit rather than direct to battery. I want them on in city riding so folks can see me coming rather than for lighting the road which is why I am going with low voltage.
I just got this bike and started reading the forums and there is a plethora of good lighting information spread out so it there a summary of the best lighting mods for the bike and best source: like headlight bulbs, led tails, led turns volt meter?
Please be kind to this newbie, first post
BasherBob.
1995 VN 750 - 24000 miles.
St. Charles, MO
basherbob is offline
post #2 of 4 (permalink) Old 10-13-2008, 11:07 AM
dirtrack650's Avatar
Sounds like you could use a set of LED driving lights for your purpose. LEDs consume next to nothing for amps, look great with their 'blue/white' light, and can be wired into virtually any HOT wire w/o loss of wattage or charging problems. They provide the extra visibility you're looking for.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #3 of 4 (permalink) Old 10-13-2008, 06:14 PM Thread Starter
basherbob's Avatar
That sounds like the ticket, got any suggestions where to get them. I think I saw them at walmart for around $15.
post #4 of 4 (permalink) Old 10-14-2008, 10:13 PM
Welcome to the Vulcan Forum, basherbob. We usually welcome you on the newbie checkin forum, but seeing you are already in the door, pull up a chair and sit yourself down. Come back often.
