Voltage Meter gauge and Relay - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 09-30-2016, 05:30 PM Thread Starter
AMH
Guys,
After the installation of my Stator and regulator, I want to add a Voltage meter gauge and I have read many posts about connecting directly to the battery or connecting to the headlight bucket. I really like to go directly to the battery, so I can get the exact charge and voltage of the bike.
Do you have any suggestions on which wire I should tap into ? Also, I found a great post from a fellow Vulcan owner about relays below but one question.
(PLEASE SEE ATTACHED RELAY IMAGE)
If #86 is getting power from Headlight bucket, then do you still need power from battery terminal and FUSE going to #30 ?
# 86 would be the power supply from the headlight bucket, no switch is needed here, the lead acts like a switch. It is illistrated this way if you wanted to be able to kill the supply. (ex. L.E.D. lighting system or other accessory)
# 87 would be the + power lead to the meter. (middle lead don't beleive is used)
# 85 & 87 can share the same ground, just make sure it's a good one.
# 30 self explainatory!
Thanks in advance for all the help and support!!
AMH is offline
post #2 of 6 (permalink) Old 09-30-2016, 05:52 PM
Expendable newbie
evulcannibal's Avatar
Yes you do. #86 is used kind of like a on and off switch. When it gets power then it closes the circuit on 30 and 87 which is kind of like connecting two wires together. If you connect battery power to 86 then the relay will always be on and 30 and 87 will always be connected.
Don't take my word for it. I'm just a foolish newbie.
When in doubt, just know that I am only joking around.
95 VN750
Top speed is 112 mph at ~7900 rpm
Blacked out engine
Dry rusty splines finally lubed for the first time
R/R relocated to the side of fuse box
Rust removed from tank
In line fuel filter, 23-28 micron rating
Gear indicator
LED turn signals & brake light
16 color LED engine light up & underglow
evulcannibal is offline
post #3 of 6 (permalink) Old 09-30-2016, 11:21 PM Thread Starter
AMH
Very cool..... thanks so much for clearing this up! I'm going to order my Voltage meter next week just to keep an eye on the charging system.
AMH is offline
post #4 of 6 (permalink) Old 10-03-2016, 04:43 AM
When you say: # 85 & 87 can share the same ground, just make sure it's a good one.
I just want to make sure you mean that you're tying the ground of the relay and the ground of load supplied by pin 87 (voltage readout) together, not 85 and 87 directly. Sounds like you're on top of it, but you never know who might be reading.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #5 of 6 (permalink) Old 10-06-2016, 03:35 PM Thread Starter
AMH
Thanks so much. So, In simple terms I just need to make sure that 85 is connected to a good ground screw on the bike's frame and take 87 and connect it to the same screw or bolt on the frame of the bike, right?
AMH is offline
post #6 of 6 (permalink) Old 10-07-2016, 09:37 AM
85 to a ground screw.
87 to the positive lead of your voltage readout
negative lead of your voltage readout to the same ground screw as 85
87 can never connect directly to ground. It has to 'run' something with the current or the fuse will blow.
Cheers!
Thorn is offline
