Stator replaced, 2 R/R's and still not charging - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 10-10-2008, 06:47 PM Thread Starter
ryn
Well I replaced my stator and am getting 30 VAC at idle up too 120+ VAC nearer red line at the three stator leads. I believe that is what I should be getting. My problem is I have tried 2 r/r's and all I get is about 13.5 volts when any RPM is sustained for an amount of time. The battery is at about 12.6 volts when disconnected, and it drops to about that when given throttle, but when held at any RPM it levels out at 13.5. The second R/R was verified working on another bike. I'm thinking that maybe I have bad connections on one or more of the non yellow wires going to the R/R, Does this sound reasonable? How can I verify those three wires are going where they need to be going?
Thanks
-ryan
ryn is offline
post #2 of 12 (permalink) Old 10-10-2008, 07:27 PM
Vintage bike addict
antiq's Avatar
I'm definitely not an expert but it sounds like it's working as it should to me.
Eleanor Roosevelt.
antiq is offline
post #3 of 12 (permalink) Old 10-10-2008, 08:03 PM
On His Lady Vulcan
wkrizan's Avatar
What he said
Pictures of the "Ladies"
wkrizan is offline
post #4 of 12 (permalink) Old 10-10-2008, 09:13 PM
How old is your battery? Is it an MF or regular? Have you had the battery load tested?
2001 VN750
Vista Cruise Control
V-Force shield
Kawasaki Saddlebag supports
Fixed trunk hinge
TOC MCCT
Clear Alternatives LED tail light
Knifemaker style floorboards
Knifemaker style dash
Avon Venom X 110/90 Front
Avon Venom X 170/80 Rear
Big Crank AGM battery
25,100 miles as of 04/20/2010
lancer19 is offline
post #5 of 12 (permalink) Old 10-10-2008, 09:27 PM
Crobins365's Avatar
I think he should be seeing the voltage spike higher than 13.5 - somewhere closer to 14.5v would seem more reasonable to me if the system is going to replenish the battery. ??
C
Crobins365 is offline
post #6 of 12 (permalink) Old 10-10-2008, 09:44 PM
On His Lady Vulcan
wkrizan's Avatar
Mine only reads 13.7v max. ever sense I replaced my stator and it has yet to give me any issues with starts or kind of charging problem....ummmm dunno?????????
Peace
wkrizan is offline
post #7 of 12 (permalink) Old 10-11-2008, 08:46 AM
here is a colored schematic of the charging system to help determine where the yellow wires are supposed to go.
here is a picture of the R/R connector pin colors
I would check all connections in the charging system for good connections, also check the male plug to the R/R for corrosion. Have you relocated the R/R? Most people move it for heat reasons, but there are also issues to its stock location due to battery acid dripping down on it from the batter box, which causes corrosion.
Do you have the TS Proceedures for the charging system?
if not here is the "Clymers" guide to trouble shooting the charging system.
post #8 of 12 (permalink) Old 10-11-2008, 10:35 AM Thread Starter
ryn
Thanks that exactly what I was looking for.
It's a Brand New mf battery
The R/R is just sitting on the rear fender behind the battery a bit until i can get everything sorted out, then I will finish my bracket and mount it between the side cover and rear wheel.
I had no plug for the R/R I was sent one that I soldered on.
From what I have been told the voltage should raise with RPM's. I get the highest voltage at idle (13.5) or when I keep a constant RPM for a few seconds or more, that could be 1000 rpms, or 4500, it levels at 13.5.
But when accelerating it drops to 12.6. and That is what has me most concerned.
thanks
-ryan
ryn is offline
post #9 of 12 (permalink) Old 10-11-2008, 10:48 AM
warm the bike up to normal operating temps, then check your voltage at Idle, 1500 RPMs, 3000 RPMs, and 5000 RPMs. the voltages should keep increasing as the rpms increase... 4000 and 5000 should be around 14.5 volts +- 0.9 volts
post #10 of 12 (permalink) Old 10-11-2008, 12:02 PM
Calif Rider
weh44att's Avatar
I agree with Slim and Corbin your readings should be more than 13.5. Above 2000 it should be easily in the 14's. May still be a bad connection. Your reading at the stator wires or great. It seems after that you are loosing a good connection. Just a little corrosion can cause this. I had that problem and it causes the wires to heat up because to much power is trying to go through less wire, or the RR gets hotter than normal also.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
