Bike won't start after Tuxedo mod - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 08-14-2016, 03:21 AM Thread Starter
DR.BADNEWS's Avatar
Today I finally finished piecing my bike back together after installing the tuxedo mod, replacement stator, and reinstalling the surge tank and air boxes, however, I wasn't able to get it up and running. The bike just cranks for a minute or so until the battery dies. Tightening the idle speed adjustment screw makes the bike crank faster, but it unresponsive to choke and throttle movement. I feel pressure coming from the exhaust pipes, but I'm not getting any backfiring or even sure that I'm getting spark at the plugs because it doesn't sound like it's firing.
Before I disassembled it, the bike ran off the battery just fine until it'd die, and I didn't mess with timing or anything valve related in the process. I checked the jets when I had the carbs off and they looked clean as a whistle, so I didn't bother inspecting much deeper into finding the float bowls. And I've made sure all the grounds to my knowledge are secured. Pick-up coils are in the stock positions. And I can't think of any missed connections.
The bike has had straight pipes, a jet kit, and was ear shaved by a previous owner, but I just reinstalled the stock intake with K&N filters. I did the two wire and blue wire mods after the stator failed in November to keep it running for as long as I could get away with it. I was concerned about fuel to air mixture, but I figured it'd atleast start and run a little groggy if that was the case. I adjusted the idle fuel/air mixtures screws to 2 turns out, but I'm not sure if I need to bring them in or out with the jet kit.
Today was also 100F here in Virginia, so I wouldn't imagine it'd take a lot to get it started. But it was having a bit of hot starting issues before I took it apart, or maybe that was because the battery was nearly dead after riding it around.
The only electrical connections in question I can think of is the red and green wires that plug into a solenoid looking thing in front of the battery and the two prong outlet on the other solenoid looking thing on the right. But switching those around seemingly did nothing to help. There's some sort of clicking in the electronics under the seat when it cranks, but that may be normal.
Can't think of any other important wires or connections, I don't know much about electronics and circuits. I'm gonna check and replace the spark plugs tomorrow with iridiums, because I do that with all my vehicles. Then look into the coil relay mod, but that shouldn't be necessary if I did everything right. Last case scenario I'll adjust pick-up coil clearance to .2mm or whatever, but I REALLY don't want to take the crank case apart again after filling it up with oil.
Can anyone explain what I might be missing here?
EDIT: Bike finally started after 4-5 hours of frustration trying to get it started without changing much. Bike runs like **** at low-end speeds, but was slightly improving over the trip to and from work with a butt load of seafoam and a near full tank of fresh gas. Bike ran for about one day then battery already killing itself in less than 30 miles on a full charge... Another stator gone bad, or is something not wired up correctly here?
Last edited by DR.BADNEWS; 08-30-2016 at 09:19 PM. Reason: Change in circumstances
DR.BADNEWS is offline
post #2 of 17 (permalink) Old 08-14-2016, 03:27 AM
1: Is the petcock turned to "on"
2: Check spark! Pull a plug, hold it against the frame and see if it sparks.
3: Check for fuel.. by pulling a plug and seeing if it's wet (if no spark)
post #3 of 17 (permalink) Old 08-14-2016, 05:05 AM
What he said. Hopefully #1 fixes it. if not, the answers to 2 and 3 will lead to the next troubleshooting step.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #4 of 17 (permalink) Old 08-14-2016, 10:35 AM
Agreed, check #2 and 3.
If it sat a while during the mod, ethanol may have caused the petcock diaphragm to stick closed. Or it can be a stuck float valve in the carbs. A prime into the the intake may get it going, using gas or starting fluid.
But we need to verify spark and fuel in order to proceed.
post #5 of 17 (permalink) Old 08-27-2016, 12:21 AM Thread Starter
DR.BADNEWS's Avatar
I'm really hoping it's the spark plugs or previously being flooded. Could I blow into the gas cap to get gas through the petcock if it clogged? I only sat for a couple months...
post #6 of 17 (permalink) Old 08-27-2016, 12:27 AM
If you were me you'd ask a prospect to do it
post #7 of 17 (permalink) Old 08-27-2016, 10:46 AM
Probably won't work. Might try applying vacuum to the vac line and see if the gas flows..
post #8 of 17 (permalink) Old 08-27-2016, 02:18 PM
This. The petcock will only let fuel through if a vacuum is applied to the 'middle' line. Then fuel will flow out both sides under gravity. Something as small as a syringe can provide the appropriate vacuum.
Thorn is offline
post #9 of 17 (permalink) Old 08-27-2016, 09:30 PM
If it has a prime function should work
post #10 of 17 (permalink) Old 08-28-2016, 06:16 PM Thread Starter
DR.BADNEWS's Avatar
Changing the spark plugs did absolutely nothing for me. the bike seems like it really has to struggle and huff when cranking and it'll crank and crank for about 2-3 minutes before the battery dies. I'm gonna check to see if the spark plugs are "wet". Can crush washers be reused like that?
