led headlight - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 13 (permalink) Old 08-07-2016, 06:39 AM Thread Starter
led headlight
ok I pt a led headlight on my 97 vn750a and the headlight out light and the hi beam flickers. the high beam stills works and the low beam still works. any thoughts????? Scott
scjpll1 is offline
post #2 of 13 (permalink) Old 08-09-2016, 03:02 PM
Wiring/contacts loose? LEDs also have less persistence than incandescent bulbs but given that the stator has three lobes and RPM is at least 800 that shouldn't matter to your eye.
One thing to consider is that the stator/regulator are sized for the system. The LED uses much less power than the standard headlight which is always on and a main dumping point for power. This means, unless you have something else to eat the power, the excess is dumped thru your regulator. I bought an LED bulb for mine but reconsidered after thinking it thru.
ArkTinkerer is offline
post #3 of 13 (permalink) Old 08-09-2016, 03:48 PM
reserve lighting unit.. if its still there, you will need to bypass it.
led lights do not get along with it
michiganteddybear is offline
post #4 of 13 (permalink) Old 08-10-2016, 05:34 AM Thread Starter
led head light
Ok were would I find the info on doing this...
scjpll1 is offline
post #5 of 13 (permalink) Old 08-10-2016, 11:16 AM
Right here
https://www.vn750.com/forum/19-electr...9946?_k=5mvspk
post #6 of 13 (permalink) Old 08-10-2016, 01:21 PM
doc, that link is for the blue wire mod. I have not done either blue wire, or RLU bypass on my bike... I am not sure, but the blue wire does not bypass the RLU, only the JBox trigger circuit
post #7 of 13 (permalink) Old 08-10-2016, 01:57 PM
I thought it bypasses the relay.fixed my relay issues
post #8 of 13 (permalink) Old 08-10-2016, 02:47 PM
it will fix a relay issue (inside the junction box), but the RLU is seperate. it monitors the current flowing into the headlight (which ever filament is lit), and if its not enough, switches to the other filament and lights the warning on the dash.
Note: which ever filament is lit, which means if low beam is on, and not enough current (as an LED light would do) it will switch to high beam (which, wont have enough current either), and switch back, and switch back, ect. causes flickering/flashing of the headlight
Thorn likes this.
post #9 of 13 (permalink) Old 08-22-2016, 07:03 PM
Know-It-All White-Trash
seems pretty common, im waiting for mine to come in so have only studied it.
check out this fix and please follow-up if you find a flicker fix for vn750s.
2 Audi BMW Mercedes CAR Warning Anti Flicker Cancellers FOR HID Conversion KIT | eBay
"Spock2.2" 3 clutches,3 engines, FK TUX MOD! Clubman bars w/ trimmed lines, Progressive shocks, FLO filter, gages app, RAM mount, custom light and signals. UV lights(antifreeze box and socks glow),(Jetted) V&H pipes, Brisk 360, Kuryaken HWY pegs (leg indifference disability), Viking bags, wet ears, Oil temp cap, Mosffet r/r under saddle bag. [email protected] 530ft 1/2 throttle 5th gear. i am alive because they see me, they hear me! I can downshift as fast as I can get the hell outta the way!
Damon FTW is offline
post #10 of 13 (permalink) Old 08-22-2016, 07:54 PM
https://www.vn750.com/forum/19-electr...ting-unit.html
Surprised that post didn't get stucked.
