Turn lights - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 06-27-2016, 02:47 PM Thread Starter
Turn lights
What after market turn lights from ebay would fit my 1986 kawasaki vulcan 750 without modifications I need all 4 thank you in advance.
poncho26 is offline
post #2 of 18 (permalink) Old 06-27-2016, 02:52 PM
None.some modifications will be needed
post #3 of 18 (permalink) Old 06-27-2016, 02:53 PM
yup, either mounting method or electrical modification, or both depending on what you get
post #4 of 18 (permalink) Old 06-27-2016, 03:05 PM Thread Starter
Do you guys know what's needed for something like this?
poncho26 is offline
post #5 of 18 (permalink) Old 06-27-2016, 03:08 PM Thread Starter
Or this
ID:	32602   Click image for larger version
poncho26 is offline
post #6 of 18 (permalink) Old 06-27-2016, 03:11 PM
Longer mounting bolt and two big washers.
post #7 of 18 (permalink) Old 06-27-2016, 05:08 PM Thread Starter
And they should have 2 wires each?
poncho26 is offline
post #8 of 18 (permalink) Old 06-27-2016, 05:10 PM Thread Starter
Also if I buy leds will this relay work, what you guys think?
poncho26 is offline
post #9 of 18 (permalink) Old 06-27-2016, 05:11 PM Thread Starter
This is the relay
poncho26 is offline
post #10 of 18 (permalink) Old 06-27-2016, 06:03 PM
the 1st ones you linked are the ones I have, but silver housings.. they are LED, and NOT very bright at all.. cant really see them in day, nite is fair..
they do require an electronic flasher, part number is EP-34, avail most any auto parts house, for under 20 bucks. this flasher is direct plug and play, no mod needed to use.
the one you linked looks like it has variable flash rate.. however it may not be sealed for weather (our flasher is exposed, mounts behind battery)
