30mA parasitic draw - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 06-13-2016, 02:52 AM Thread Starter
30mA parasitic draw
Found a dead battery the other day and diagnosed it as a 30mA parasitic draw on the "main" fuse circuit. If I remove the main (30A) fuse the draw drops to 0. I've tried disconnecting the ignition module, the fan, every plug behind the headlight but not determined where the draw is.
I don't have an electrical diagram isolated by circuit.
Any suggestions of likely spots to focus on?
-Robert
RobertGary1 is offline
post #2 of 10 (permalink) Old 06-13-2016, 11:30 AM Thread Starter
R/r. . Unplugged it and the draw went to 0. This is unfortunate because I thought I'd finally found a good brand of r/r. Other brands I'd tried over charge. This one charges perfect.
-Robert
post #3 of 10 (permalink) Old 06-13-2016, 02:09 PM
Is it a stock style regulator? Could be the sense wire.
I have no draw issues with my MOSFET. If I leave my bike for longer than a week I throw it on a tender, though.
post #4 of 10 (permalink) Old 06-13-2016, 02:40 PM Thread Starter
Yes, its the stock style. I've got a pile of r/r's at this point so I can swap it with another and verify if its an issue in the r/r itself.
This just started 2 weeks ago. This r/r was good up to that point and I was able ot leave the bike for weeks.
-Robert
post #5 of 10 (permalink) Old 06-14-2016, 11:14 AM Thread Starter
Swapping the regulator fixed the issue so it's in the regulator. Too bad because I was finally happy with the way this one charges and it was a direct fit.
-Robert
post #6 of 10 (permalink) Old 06-14-2016, 11:50 AM
Curious about the high charge rate you were getting. Numbers?
post #7 of 10 (permalink) Old 06-14-2016, 01:24 PM Thread Starter
With the crappy Celtric regulators I saw as high as 18v. I bought one and got two under warranty until I gave up on them. I have an "unbranded" regulator now that holds a fairly nice voltage but recently developed this parasitic draw.
-Robert
post #8 of 10 (permalink) Old 06-14-2016, 01:33 PM
Wow, yep, way too high for battery life.
post #9 of 10 (permalink) Old 06-14-2016, 05:06 PM
Expendable newbie
evulcannibal's Avatar
Looks like the regulator ain't regulating.
That's one of the risk of cheap electronic parts. They look the same so you think they'll perform the same, but no.
Don't take my word for it. I'm just a foolish newbie.
When in doubt, just know that I am only joking around.
95 VN750
Top speed is 112 mph at ~7900 rpm
Blacked out engine
Dry rusty splines finally lubed for the first time
R/R relocated to the side of fuse box
Rust removed from tank
In line fuel filter, 23-28 micron rating
Gear indicator
LED turn signals & brake light
16 color LED engine light up & underglow
evulcannibal is offline
post #10 of 10 (permalink) Old 06-19-2016, 12:46 AM Thread Starter
I bought a DB Electric regulator. So far so good.
