Kawasaki Tester? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 05-22-2016, 02:43 PM Thread Starter
Kawasaki Tester?
Ok I have to test my stator and r&r yet I can only find meters with 200 ohms and up. I heard there's a special tester. What alternatives or where can I get this tester?
Than you!
Kristoco
Kristoco is offline
post #2 of 4 (permalink) Old 05-22-2016, 03:19 PM
200 ohm would be the max for that range.. they will usually read down to .1 or some even .01 ohms
michiganteddybear is offline
post #3 of 4 (permalink) Old 05-22-2016, 03:35 PM Thread Starter
So when I hitched my meter to the r&r running it stated 26. Something and that was the negative on the m and positive on b as stated in the testing info.
So am I doing something wrong?
Kristoco is offline
post #4 of 4 (permalink) Old 05-22-2016, 05:42 PM
....First you speak "OHMS"..............then you speak 26... running....
OHMS is a resistance reading "WITH NO Voltage APPLIED ! "
"Running" is a VOLTAGE Reading ! AC volts from pick-up coils...DC Volts at R&R and Battery !
You may have burned (up) your Meter Ohms Scale ....to inaccuracy or zero readings !
