Headlight woes - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 05-04-2016, 12:42 PM Thread Starter
Crowley
crowley1027's Avatar
Headlight woes
Blue wire bypass done. Voltage at headlight plug gives me .11 volts regardless of high beam selector position, and the dash light doesn't come on for high beam.
crowley1027 is offline
post #2 of 14 (permalink) Old 05-04-2016, 01:16 PM
calebj's Avatar
At some point, has the headlight worked since doing the bypass?
1986 VN750 27k miles
1999 EN500 32k
1983 GL650i in pieces. Someday it will ride again.
calebj is offline
post #3 of 14 (permalink) Old 05-04-2016, 01:26 PM Thread Starter
Crowley
Worked fine til teardown.
post #4 of 14 (permalink) Old 05-04-2016, 01:28 PM Thread Starter
Crowley
Can I pull the blue wire on a toggle switch wired to the battery?
post #5 of 14 (permalink) Old 05-04-2016, 01:54 PM
yes, but also add an inline fuse to be safe.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #6 of 14 (permalink) Old 05-04-2016, 02:11 PM
Thinking about this, bypassing the JB by jumping the blue wire to the battery won't do you any good if you're currently getting 12v out of the JB on pin 17 (the new location of the blue wire after the blue wire mod), which you should be if the tail fuse is good like you claimed. You'd be bypassing good circuitry, and the problem downstream would still prevent the headlight from working.
short story: check for voltage there before rewiring.
Thorn is offline
post #7 of 14 (permalink) Old 05-04-2016, 02:19 PM Thread Starter
Crowley
Will do. Should be a constant 12v out of the blue wire with the key on, right?
post #8 of 14 (permalink) Old 05-04-2016, 02:23 PM
If your blue wire is in the top back position of the JB, yes.
Thorn is offline
post #9 of 14 (permalink) Old 05-04-2016, 03:09 PM Thread Starter
Crowley
No voltage to blue wire from jb. Pulled blue wire from plug and touched to positive terminal, light lit up. Working on a switch right now. What can happen if I don't put a fuse inline?
post #10 of 14 (permalink) Old 05-04-2016, 03:47 PM
double-check your main and tail fuses. should fix your problem without rewiring.
if you don't put a fuse inline, a short can kill your battery or start a fire. You said you blew a fuse earlier ... whatever blew that fuse would have done more damage without the fuse.
Thorn is offline
