Rear fender woes - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #1 of 24 (permalink) Old 05-03-2016, 01:34 PM Thread Starter
Crowley
crowley1027's Avatar
Rear fender woes
Before I take the rear fender off to check wiring, am I missing anything?
The brake light wires had to be extended, so I have 3 blue wires to connect to the harness. The license plate light is connected correctly.
Brake Light will light up with a brake press, but doesn't have a running light. Also, the license plate light doesn't light.
Tail fuse is fine.
crowley1027 is offline
post #2 of 24 (permalink) Old 05-03-2016, 02:46 PM
calebj's Avatar
There's a red wire that should be connected to the ignition switch. It's tied into both the brake light and license plate light, and sounds like your problem.
Thorn likes this.
1986 VN750 27k miles
1999 EN500 32k
1983 GL650i in pieces. Someday it will ride again.
calebj is offline
post #3 of 24 (permalink) Old 05-03-2016, 03:47 PM
The tail fuse is unused with the stock harness. (if someone knows of a model that DOES use the tail fuse, please let me know)
One thing you can do to narrow down the problem is put the bike in park. The ignition switch uses different wiring in that position. If you get lights in park, the problem is the white wire at the ignition switch. If you don't get lights, then check the red wire from the ignition switch to the tail lights/license as calebj suggests.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #4 of 24 (permalink) Old 05-03-2016, 04:13 PM Thread Starter
Crowley
Is the red wire part of the harness and in a connector? The only reds I'm finding are at the coils... The other one(s) are tied up in connectors. Going to try the park selection noem
post #5 of 24 (permalink) Old 05-03-2016, 04:49 PM
red wire at ignition connector and red wire at tail light connector (the other two are blue and black/yellow) and red wire at license connector (the other wire is black/yellow). Should be red on both sides of each connector listed. The red wire at the coils is an unrelated wire from the killswitch.
Thorn is offline
post #6 of 24 (permalink) Old 05-03-2016, 05:24 PM Thread Starter
Crowley
Red wire at tail light and license light are connected, going to take the tank off to check the (red colored?) connector by the front coil.
Headlight is out too, does that still lend to the red wire theory?
post #7 of 24 (permalink) Old 05-03-2016, 05:25 PM Thread Starter
Crowley
I've blown the tail fuse by shorting out the taillight (taping all the bare connectors together like an idiot).
post #8 of 24 (permalink) Old 05-03-2016, 05:55 PM
IF you've done the blue-wire mod/headlight relay bypass, then the headlight would be on the tail fuse ... that might explain some of what's going on?
If you haven't done the blue wire mod, what color wire is in the very top-back corner of your junction box connector? (pin 17 in the diagrams)
The red wires to tail and license are indeed connected to each other.
Thorn is offline
post #9 of 24 (permalink) Old 05-03-2016, 05:57 PM
I don't think there's a connector under the tank that would be involved? can you just check for continuity between the ignition switch and the tail light?
Thorn is offline
post #10 of 24 (permalink) Old 05-03-2016, 07:08 PM Thread Starter
Crowley
Ignition switch - where the key goes. The connector goes down to the cluster under the tank, around the front coil. Where would I check continuity? The tail light side is easy but where in the front part of the bike should I test? There are no exposed wires really...
