Electronic - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 13 (permalink) Old 05-01-2016, 02:40 PM Thread Starter
Electronic
When I go to take off bike acts like it don't have enough power to go but it idles and even can reb it up just fine
Polorpop is offline
post #2 of 13 (permalink) Old 05-01-2016, 02:48 PM
Maybe the sidestand switch.
Or weak fuel delivery, it takes relatively little fuel to rev high in neutral compared to trying to drive.
Is it trying to die completely or doing something else?
post #3 of 13 (permalink) Old 05-01-2016, 03:01 PM Thread Starter
It just completely dies I had to do the 2 wire mode to make my new RR to work if the yellow wire on the 10 pin is not making a good connection can that be it
Polorpop is offline
post #4 of 13 (permalink) Old 05-01-2016, 03:11 PM
Not sure, but if the yellow/red is still connected on the 10-pin, the sidestand switch may still be involved.
Dying completely does sound like the sidestand sw. is killing it.
What year?
post #5 of 13 (permalink) Old 05-01-2016, 03:20 PM Thread Starter
Polorpop is offline
post #6 of 13 (permalink) Old 05-01-2016, 03:22 PM Thread Starter
Can I unhook the side switchstand
Polorpop is offline
post #7 of 13 (permalink) Old 05-01-2016, 03:33 PM
No, I think that will be the same as if the kickstand was down. Would need jumpers on certain wires , I think.
Could try a shot of WD40 in the switch, or clean it.
There should be info on the site about how to jump that switch to disable it.
post #8 of 13 (permalink) Old 05-01-2016, 05:05 PM
X2.they need to be connected together
post #9 of 13 (permalink) Old 05-02-2016, 08:02 AM
X3 connect the two kickstand wires together at the switch to bypass the switch.
The yellow wire on the 10 pin only triggers the headlight solenoid. It has no effect on the engine.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #10 of 13 (permalink) Old 05-02-2016, 08:19 AM
RoadHopper's Avatar
X - 1... i think . . . maybe...
when i took off my kickstand switch, i took it off as it poked out of the harness and removed the whole switch gizmo from the stand. Then i checked the switch itself, and... it's normally open. meaning...
when the kickstand is down, it's pressing the button in. That closes the switch and the bike won't run.
when the kickstand is up, the switch is spring pushed back out, that's normally open, i.e. its natural state.
So when i pulled it off the harness, side, i taped the two wires around each of them with some electrical tape, then taped the two already taped ends onto the harness with a little more to basically hide them.
I stand corrected if i'm wrong about this, but, please let me put my kickstand down before you push on me to lean me since i am standing corrected and stuff.
1987 VN750 California - "Lydia"
Reupholstered leather seat w/matching lockbox.
Rebuilt battery cage
AGM battery
Murican MCCT
Redesigned Rear - LED Tag/Signals/Harness
RoadHopper is offline
