Stator Waveform with an O'scope. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 08-23-2008, 04:36 PM Thread Starter
IBEW 915 Electrician
hctublerub's Avatar
If you have a DC power supply you should see what you see on a battery but possibly have some ripple due to AC source not being filtered. This should be similar to an alternator/rectifier system on a car or a stator/rectifier system on a bike.
If you can put a DC meter on your battery while the bike is running, can't you use a standard O'scope in the same manner to check the health of your stator by observing the waveform of the output? The D C meter will only give you the DC component of the voltage.
If the stator is healthy it should present a nice sinusoidal waveform with a given P to P voltage? How much of an AC component should you see at the battery terminals?
I have a couple of O'scopes laying around gathering dust.
'01 Vulcan 750
Irridium Plugs
hctublerub is offline
post #2 of 2 (permalink) Old 08-23-2008, 06:40 PM
You are correct a scope will picture the wave form both before and after the rectier. Also a meter can be used on AC and give you a pretty good idea of the RMS voltage.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
