Ignition system woes - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 4Likes
post #1 of 26 (permalink) Old 04-21-2016, 09:52 PM Thread Starter
I'm a rider
One1's Avatar
I have no signal at the starter solenoid when I hit the button, Verified the button and switch were in working order. Checked all plugs on the main harness under the tank. checked all fuses, connections to fuse block.
Side note, headlight had no power either, if relevant to the same circuit. I get tail light and brake light both working.
IDK if headlight power and ignition for starter are on same pinout somewhere?
Anyone have a flow chart of the ignition system voltage?
I found all 5 diagrams floating around here. Doesn't help me much to have all of them different.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #2 of 26 (permalink) Old 04-21-2016, 10:25 PM
Headlight stays off until the engine starts, unless you have the headlight relay bypass in place.
Sounds like you need the Two-Wire mod, the start relay in the JB seems to have failed.
post #3 of 26 (permalink) Old 04-21-2016, 10:27 PM Thread Starter
I'm a rider
One1's Avatar
I've had the headlight mod for so long I forgot I ever did it. (on the other bike)
1981 KZ750
One1 is offline
post #4 of 26 (permalink) Old 04-21-2016, 10:31 PM
So, you don't have the headlight bypass on this bike? Headlight is functioning normally then.
post #5 of 26 (permalink) Old 04-21-2016, 10:45 PM Thread Starter
I'm a rider
One1's Avatar
Problem is I just did the 2 wire mod for both red black and all black and neither worked.
1981 KZ750
One1 is offline
post #6 of 26 (permalink) Old 04-21-2016, 10:53 PM
Test continuity on the black/red at JB to the start button?
Apply 12v to the yellow/red off the JB?
post #7 of 26 (permalink) Old 04-21-2016, 10:55 PM Thread Starter
I'm a rider
One1's Avatar
I'm not going back out tonight so any ideas to try for tomm are appreciated.
1981 KZ750
One1 is offline
post #8 of 26 (permalink) Old 04-21-2016, 11:36 PM Thread Starter
I'm a rider
One1's Avatar
i had previously verified the button operational so my question would be what are the voltage conditions of these wires? switch on?
I tried to locate it myself but the diagram in color you posted stickied doesnt have a B/R on the JB at all.
1981 KZ750
One1 is offline
post #9 of 26 (permalink) Old 04-22-2016, 01:02 AM
The electrical route of the ignition is as follows:
battery to junction box pin 1 (white/red on small connector)
main fuse, 30 amp
junction box pin 2 (white on small connector) to two pins on the ignition switch (white/black, and white)
Ensure ignition is 'on'
the white/black wire powers the turn signals
the white wire powers two branches:
1. returns power (brown/white) to pin 6 of the junction box (brown/white)
this powers the headlight (via another fuse in JB). Since you've done the headlight mod, the headlight should be on with the ignition on but the engine not running.
2. send power (yellow) to engine stop switch (yellow/red)
send power (red) to starter button (red)
send power (black/white) to junction box pin 11 (black) and ignitor (red/white)
If your turn signals don't work with the ignition on, you've either got a blown main fuse or a loose wire between the JB and the ignition switch
"I did the 2 wire mod with both the black and red black" OMG! Random wire splicing! You need to connect wire 11 (black/red, sometimes just black) to wire 13 (yellow/red). Your picture looks like the right wires, but the connectors are a bit blurry (the connector pin position is the more reliable way to tell, not the wire color). bottom front wire to third-up front wire.
If your turn signals DO work with the ignition on, the fuse is good and you're probably getting power to the ignition switch, though the white wire might be loose anywhere between the white/black & white spice and the switch.
If your fuse is good, checking for 12v at each connector listed above should lead you to the problem. (assuming the headlight and starter are failing due to the same problem)
Speaking of failing, if you've blown the 30 amp fuse, you might have a short to ground somewhere. Check to make sure there is no continuity between junction box wire 2 (white on small connector, checking the wire, not the JB pin) and ground. I don't see an all-black wire in your picture ... wonder where you spliced 12v to ...
One1 and RoadHopper like this.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #10 of 26 (permalink) Old 04-22-2016, 02:17 AM
Ok, the button works. But is the wire to the JB any good? Check continuity.
Near battery voltage should be present on the blk/red or blk at the JB when the button is pushed.
That was explained in the thread for the mod.
