Turn Signal Confirmation - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
  • 1 Post By thtanner
  • 1 Post By mikesutch
post #1 of 9 (permalink) Old 04-21-2016, 12:45 PM Thread Starter
RoadHopper's Avatar
Would somebody check to see if this is the same on their bike please? Mine is an '87.... My front turn signal lamps are two-state ( three wires with bulbs that have two bumps on the bottom ) but my rear turn signal lamps are only one-state ( two-wires with one bump on the bottom ).
Is that right?
RoadHopper is offline
post #2 of 9 (permalink) Old 04-21-2016, 12:53 PM
Yup, same as my old original ones. They front signals were only using 2 of the 3 wires tho.
Some places had them setup as running lights or something?
post #3 of 9 (permalink) Old 04-21-2016, 12:57 PM
Is that right?
Yup
The front are also running lights......
I made my Rear 3 wire for additional running lights.....
I have LED inserts from kcdqg...
post #4 of 9 (permalink) Old 04-21-2016, 12:59 PM Thread Starter
RoadHopper's Avatar
Thanks! and now... hmmm... meh... i have three wires from the harness up front... and... took me twice ( murphy's law ) to figure out which hot was for which function... signal or running... okies... so i just assumed that the rears were the same... i designed an LED prototype for the rears.... was about to compare it to the bulb... and.... huh?? wtf? I wired the rear for 3 wire... running/signal.
Okies. so, i guess, the turn signal unit just increases the voltage when it wants to turn in the rear? or.... do you actually have running lights AND a signal out back? or are the rear just off then signal?
Bike is out in the lot... fender is up here in the loft with the battery.
post #5 of 9 (permalink) Old 04-21-2016, 01:06 PM
Pretty sure the rear is just off and on again signals. When working on your conversion that's all I'd worry about unless you wanted to upgrade to a running light situation, which we already have the headlight lit for.
RoadHopper likes this.
post #6 of 9 (permalink) Old 04-21-2016, 01:13 PM
mikesutch's Avatar
Thtanner is correct. The back are just signals. I recently found this out when verifying if all my lighting was working as it was designed.
Mosfet R/R and relocated
2 wire Mod for the 1986 harness
VN750.com grill cover
mikesutch is offline
post #7 of 9 (permalink) Old 04-21-2016, 01:22 PM Thread Starter
RoadHopper's Avatar
Originally Posted by WilliamTech View Post
Yup
who/what is "kcdqg"?? How much and how do they work? Just plug right in?
The simple problem between a bulb and just shoving a bunch of LED's into the same socket... LED's need to point to the lens.
I'm using bottle caps as forms.
Name:	16 - 1(9).jpg
post #8 of 9 (permalink) Old 04-21-2016, 01:23 PM
calebj's Avatar
I'm surprised yours weren't set up as running lights with all three wires used. They're wired in on every diagram I've seen for all years.
calebj is offline
post #9 of 9 (permalink) Old 04-21-2016, 01:57 PM
PO could have unplugged the running light portion. Only 2 of 3 leads were used.
