Bad Pick Up Coils - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 4Likes
post #1 of 24 (permalink) Old 04-16-2016, 03:49 PM Thread Starter
Bad Pick Up Coils
Tested the pick up coils since I was getting no spark. Test the 4 pin connector while spinning the motor with a 12v test light...I got no hot light out of any of the connector pins. Is it possible for both pick up coils to go bad....
Markak is offline
post #2 of 24 (permalink) Old 04-16-2016, 05:00 PM
with the coils disconnected, you may not be able to measure anything comming out of them. they are magnetic pickups.
I believe they send a fairly low voltage signal to the ignitor. and its pulsed, with a very short pulse duration.
I dont think they are biased by the igniter (putting a voltage on one side of them and monitering the other leg).
best way to check them would be with an oscilloscope if I am thinking properly on their operation.
you can use ohm (resistance) measurements to check them, and there is a spec in the manual as to what they should read
RoadHopper and Thorn like this.
michiganteddybear is offline
post #3 of 24 (permalink) Old 04-17-2016, 12:10 AM
Yeah, you're not going to light a 12v light from those leads. The resistance should be 355 - 535 ohms.
RoadHopper likes this.
Thorn is offline
post #4 of 24 (permalink) Old 04-17-2016, 12:16 AM
RoadHopper's Avatar
... and as they get old and cook, they become brittle and easy to break, so BE CAREFUL. Test the ohms before and after your job.
RoadHopper is offline
post #5 of 24 (permalink) Old 04-18-2016, 09:25 AM Thread Starter
Well I spent most of the day looking for anything, I test the pick up coils (455 Ohms) after I did the pick coil MOD, then I tested the ignition coils (1.9 Ohms), ignition coils have power going to them (tested) but still zero spark going to the plugs. Im lost now, electrical gremlin! Any help would be greatly appreciated,
Mark
Markak is offline
post #6 of 24 (permalink) Old 04-18-2016, 10:04 AM
Found this fairly confusing diagram showing the IC Ignitor box wiring. Maybe someone can figure it out.
I was trying to find how the IC Ign. is powered from the junction box. Looks like maybe the red/white wire, but the diagram has me befuddled right now. Think that red/white just branches off the start circuit, discussed in the Two-Wire Mod sticky thread.
Or you may have a dead IC Ign. box.
post #7 of 24 (permalink) Old 04-18-2016, 10:07 AM
RoadHopper's Avatar
Cool
That'd be my guess, but i'ma too much a n00b to say so. Nice diagram... i'll give it a study.
post #8 of 24 (permalink) Old 04-18-2016, 10:21 AM
RoadHopper's Avatar
Okay, pretty straight forward and agrees with the other wiring stuff that is more or less accepted around here... ( see Thorn's master copy of the colors that go everywhere . . . )
The heart is basically the flywheel... and the pickups sense a weak field spike which is fed to the IC Ignitor. The IC stands for "Integrated Circuit" which in essence means it's not going to get fixed, and they ain't gunna tell ya what's in it...
... but... what is in it is two things, and possible both are the same ( which they probably are since it's cheaper to design than kludge ). There will be an amplifier/signal shaping circuit inside, basically a transistor and it only needs one, but they probably have four to provide various things like stability, regulation, and other kewlies wave shaping things that keep the circuit "safe". So... in essence, you can think of the IC as just yet another relay, but it's just special because the weak little guitar pickups down there by the wheel, get amplified just the same as an electrical guitar but... with a fuzz-box, ( seriously ) because they probably want a square wave hitting those coils ( just a guess ). The square wave has the hysteresis characteristics to give that coil a "time shaped charge" ( so you get good fire, fast, exactly when they want it, no sooner, no later then POOF, off in a flash. The coils are fed by the battery but only after it goes through the stop switch and the ignition switch ( the key ). In essence, the key and the kill switch do exactly the same thing, in opposite tandem. The JB doesn't do jack squat as far as the coils go.
Been up awhile, about ready to crash, so... obviously i stand corrected in advance. Hope this helps.
post #9 of 24 (permalink) Old 04-18-2016, 10:50 AM Thread Starter
RoadHopper,
Thanks for the info, I will check the ignition out today, is there a way to test it and you said theres a kill switch as well?
Markak is offline
post #10 of 24 (permalink) Old 04-18-2016, 11:17 AM
https://www.vn750.com/forum/showthread.php?t=18475
Try reading this.I am looking at more old posts will post more linky thingies later
