Stock plug wires OK with Iridium plugs? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 5Likes
  • 1 Post By gidaeon
  • 1 Post By Lungfishh
  • 1 Post By WilliamTech
  • 1 Post By Spockster
  • 1 Post By gidaeon
post #1 of 9 (permalink) Old 04-10-2016, 05:33 PM Thread Starter
Can stock plug wires be used with the recommended Iridium plugs DPR7EIX-9? I am confused about the whole resistance in the plug along with plug wire resistance thing from other threads.
RoadHopper likes this.
2002 vn750
AGM battery, Shinko 230 tires oversized front
Ear shaved - k&n pods, drilled clutch basket
40/138 jetting
If I can split a case and make it work - you can too!
Forum pictures:http://s150.photobucket.com/user/Gid...?sort=3&page=1
gidaeon is offline
post #2 of 9 (permalink) Old 04-10-2016, 05:46 PM
Red face
Absolutely.....DPR7EIX-9 are the BEST way to go....
New wires/wire ends are available on many part sites (if needed)....
I went with "Ron Ayers" ~~ $20.00 ? If I remember correctly---54" of wire is what is all you need for our VN750's (build your own.......easy-peasey).
enjoy
post #3 of 9 (permalink) Old 04-10-2016, 05:48 PM
RoadHopper's Avatar
I was lookin at these earlier... but if i ever bother to buy them at that price tag... it will be long after i get my engine cleaned.
https://www.denniskirk.com/powermadd...6.prd/E336.sku
using the stock plugs for now.
RoadHopper is offline
post #4 of 9 (permalink) Old 04-10-2016, 05:50 PM
Im using Stock wires with the iridium plugs. No troubles here.
Lungfishh is offline
post #5 of 9 (permalink) Old 04-10-2016, 05:59 PM
I used stock plugs for the first thousand miles or so....nothing wrong with them.
Irrirdiums are a bit more superior.
post #6 of 9 (permalink) Old 05-09-2018, 06:48 PM Thread Starter
So I finally bought these DPR7EIX-9 plugs and am totally confused as the stock wires definitely will not fit over the obviouslt larger/wider terminals of the new plugs.
Is there a trick? A tool to widen the ‘socket’ portion inside the boot? Some adapter for terminals?
I must be missing something ridiculously obvious
2002 vn750
40/138 jetting
gidaeon is offline
post #7 of 9 (permalink) Old 05-09-2018, 07:09 PM
Wink
Is there a trick? A tool to widen the Ďsocketí portion inside the boot? Some adapter for terminals?
The new plug has a threaded fitting on the top, unscrew it to expose the threaded stud, stock cap will fit right.
ubertalldude likes this.
post #8 of 9 (permalink) Old 05-09-2018, 08:07 PM Thread Starter
Wow. Ok I’m embarrassed for not looking closer ha. Thanks!
WilliamTech3 likes this.
2002 vn750
40/138 jetting
gidaeon is offline
post #9 of 9 (permalink) Old 05-09-2018, 08:16 PM
Wow. Ok Iím embarrassed for not looking closer ha. Thanks!
You're welcome!
You're not the first, there's a thread with pics around here somewhere.
