Are "YTX14AH-BS" made in CHINA batteries junk? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 3Likes
post #1 of 24 (permalink) Old 04-09-2016, 12:20 PM Thread Starter
Are CHINA made AGM or "YTX14AH-BS" batteries all junk?
I've read the verses and understand the many threads on why AGM batteries are the obvious go-to.
My questions is is everyone running USA made or TRUE Yuasa brand etc., or are you guys doing ok with the amazon and ebay re-labeled or imported ones with the same specs that say made in China or similar? There;s two obvious price brackets. I assume some that go to ebay are getting chinese.
Thinking about this specific one a member here bought (guessing chinese again?) $41 shipped.
Kawasaki 750CC Vulcan VN750-A Vulcan, 1986-2005 Motorcycle Battery (12V 14Ah)
This TMS labeled tyx14ahl is $42 but clearly chinese: https://www.amazon.com/gp/product/B0...A24FJG9QJIEUE2
2002 vn750
AGM battery, Shinko 230 tires oversized front
Ear shaved - k&n pods, drilled clutch basket
40/138 jetting
If I can split a case and make it work - you can too!
Forum pictures:http://s150.photobucket.com/user/Gid...?sort=3&page=1
gidaeon is offline
post #2 of 24 (permalink) Old 04-09-2016, 12:42 PM
cglennon's Avatar
I run true Yuasa batteries ($70) in my VN750. They last at least 7 years, can sit months without a charger and I believe that it was manufactured in the USA (Laureldale, PA plant). Date stamp it when you first put the electrolyte in and replace it 6 years from that date, and you will never be stranded due to a dead battery. I would not touch the China brands, especially in the VN750 with its tough to replace stator. Spend the extra $30 on a good battery.
ruger likes this.
Chris Glennon - Portland, OR
cglennon is offline
post #3 of 24 (permalink) Old 04-09-2016, 12:57 PM
That amazon battery is a gel cell, not an AGM. And if you're ever adding electrolyte, it's a wet cell, not a gel or AGM.
I'm running a Magnapower AGM I bought at Advance in 2012, around $80. Great battery so far, going on four years old.
Babied it the first couple of years, but it sat in the cold all this winter with no charger. Volt meter read full charge and the bike started right up after four months or so.
post #4 of 24 (permalink) Old 04-09-2016, 01:01 PM Thread Starter
Thanks! Just found USA made AGM with YTX14AHL-BS specs for just $60 shipped! I suspect its just relabled Deka since Yuasa is not agm then?
Motocross YTX14AHL-BS AGM Maintenance Free Battery - Free Shipping: BatteryMart.com
Otherwise, amazon has the true yuasa for $65. not bad at all.
http://www.amazon.com/Yuasa-YUAM62H4...sa+ytx14ahl-bs
2002 vn750
40/138 jetting
gidaeon is offline
post #5 of 24 (permalink) Old 04-09-2016, 01:14 PM
Thanks! Just found USA made YTX14AHL-BS for just $60 shipped! I suspect its just relabled Yuasa or Deka
edited out wrong info, got my links mixed up.
Skeptical about that Amazon battery being an AGM .... Both cannot be true.
Amazon: Battery supplied dry with acid bottle
post #6 of 24 (permalink) Old 04-09-2016, 01:24 PM
Not sure that Battery Mart is an AGM, because the description doesn't state that it is. Maint. Free and AGM aren't necessarily the same.
Skeptical about that Amazon battery being an AGM too.... Both cannot be true.
Those are AGM. Even says AGM on the batterymart site: Motocross YTX14AHL-BS AGM Maintenance Free Battery
post #7 of 24 (permalink) Old 04-09-2016, 01:28 PM Thread Starter
[removed false statement about Yuasa as agm]
Re: Motocross AGM, you could be right it could be false advertising or if made by Yuasa would not be AGM based on above.
"Order today and receive free standard shipping on your Motocross YTX14AHL-BS AGM Maintenance Free Battery. Only valid in the continental 48 states and not valid with any other offer. Physical address required (No PO Boxes).
Features:
Sealed, Maintenance-Free
Leakproof/Spillproof
Ships fully charged ready to install
Environmentally friendly, 100% recyclable
Vibration Resistant Design
Fully Charged out of the box
New bolts included
2002 vn750
40/138 jetting
gidaeon is offline
post #8 of 24 (permalink) Old 04-09-2016, 01:36 PM
RoadHopper's Avatar
Autozone carries them local. $80 and a $10 core discount for trading in an old battery. Not sure how close your local Autozone might be, but i can count two within a mile from here. I gave them the rotten YUASA core with the dry cells. Pulled it out right there in their parking lot.
BEWARE though: Check the shelf life and make sure it's not been sitting unattended for more than 30 days. If an AGM drains by natural reaction it will never charge again to capacity. They need to be "touched" to capacity at least once every 30 days or so.
Fortunately, that only cost me an extra trip to Autozone and they replaced it no sweat.
RoadHopper is offline
post #9 of 24 (permalink) Old 04-09-2016, 01:37 PM
It's ok, I edited my post before I saw yours.
Not sure they are both AGM though.
post #10 of 24 (permalink) Old 04-09-2016, 01:41 PM Thread Starter
I thought less babysitting was part of the point of AGM? Getting old stock is always a risk especially ordering online.
It seems hard to consistently find stock in some stores thats not over a month old (at least my local options)
2002 vn750
40/138 jetting
gidaeon is offline
