Sparkplug wire set, what to buy? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-06-2016, 10:29 PM Thread Starter
Dirt to road
duraholiday's Avatar
So one of my wires kinda melted and also I need two of the long boots. They want like 30 bucks for the boots... each. I dont really want to buy the oems and break the bank so will a 8mm universal wireset with straight boots work? They have fiber optic wire inside the insulator fyi. What have you guys used for coil wires?
For example,
http://www.autozone.com/ignition-tun...?checkfit=true
Project Bike 92 VN750
Days running: 0
Project Pictures http://s1116.photobucket.com/user/dieinghost/library/
Up coming Projects:
NOW- Getting it running....
Winter of 2015- Bobber Build
duraholiday is offline
post #2 of 4 (permalink) Old 04-06-2016, 10:40 PM
calebj's Avatar
There's a thread on here with instructions and part numbers for making your own. Dennis Kirk carries the parts to make up new boots and wire assemblies. I think it's about $20 in parts as I recall.
calebj is offline
post #3 of 4 (permalink) Old 04-16-2016, 10:59 PM Thread Starter
Dirt to road
Found a wire set for 26 bucks at NAPA. Got it to work.
Days running: 0
Up coming Projects:
post #4 of 4 (permalink) Old 04-16-2016, 11:08 PM
Sorry , Did not find this post sooner.........
Spark Plug Wire Replacement ............2007
You should consider buying NGK plug ends if you haven't already. They are
great looking and my directions are based on using them.
Dennis Kirk:
[email protected] or 1-800-328-9280
2 Part# 20306 NGK Spark Plug Cap XD05F $3.30 a piece.
2 Part# 20789 - NGK Spark Plug Cap LD05FP $4.80 a piece.
2- LD05FP and 2- XD05F are what NGK suggest to use on our VN750 bikes. :
******** All NGK caps are made for Stock 7 mm wire. *********
Note: Dennis Kirk sells 72 of 7 mm Wire. 60" is all you need for the VN750, you will have some to spare. $7.00 ?
Make sure you use copper core wire and not carbon core. 7mm is stock size, you can use 8mm but is harder to install with little to no gain.
