Can I ride while still holding the starter button in all the time? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 08-16-2008, 09:42 PM Thread Starter
Search Goddess
Dianna's Avatar
I sure hope so because that is the only way the bike stays running right now.
Sere has been down for a while in order to fix a leak at the stator cover. Engine pulled, leak fixed, splines lubed, put her back together, got her to fire up and run fine until we put the tank back on
So here is her current state
Problem: Engine only fires while start button is pushed and starter is engaged.
So far: Replaced Junction box, Ignitor box, check connectors from front switches ( on/off with key, Run/Kill) both sides of handle bars. Have power going to coils, Power at all proper places on Ignition box (CDI) and Junc. box. I'm stumped. I thought I remembered hearing about someone else having this problem and they were told of a specific place to look. Can't remember where. HELLLLP!
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #2 of 15 (permalink) Old 08-16-2008, 09:56 PM
First thing to check is your fuel source. Is there enough, is it clean, is it new.
Fuel starts to break down after 6 weeks or so.
Check the vaxuum line to the percock first. Make sure it has no splits and it fits tight. then work from there.
85 VN750 basketcase ( yes its a true 750, and no smog controls, its good to be Canadian)
It will have
a rebuilt 96 top end, rebuilt 85 bottom end
degoated, Eared
stripped, lowered, raked, bobbed,
reed valve boxes shaved
ported and polished
balanced
right side dump exhaust
heads and cylinders shaved for compression
looking for smoothbore sidedraft carbs
possibly fat bob tanks
modified vn800 or sportster drag pipes or I'll just make some
Chopperfix
Duck's Garage
Duck is offline
post #3 of 15 (permalink) Old 08-16-2008, 10:13 PM Thread Starter
Search Goddess
Dianna's Avatar
Fuel is no problem. It will stay running as long as I hold the start button.
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #4 of 15 (permalink) Old 08-16-2008, 10:21 PM
Love My Baby
rubyrick's Avatar
Sounds electrical to me, like the ignition is wired after the starter instead of the starter wired after the ignition.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #5 of 15 (permalink) Old 08-16-2008, 11:13 PM
Tape it down..
post #6 of 15 (permalink) Old 08-16-2008, 11:25 PM
Now what
Ironman's Avatar
Take the stop switch apart and see if anything's amiss there. Connections may be ok, but maybe it's worn out internally. The starter switch shares a connection with it. I don't know how the two interact, but it's worth a shot.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #7 of 15 (permalink) Old 08-17-2008, 05:23 AM
Addicted to Projects
bullwinkle's Avatar
Dianna,
I might have been the unfortunate subject sharing the problem with the starter switch.
SlimVulcanRider suggested I check the junction box, when I did I got several readings that didn't match what I should be getting. The JB had shorted out internally because of spilled battery acid. I don't think that helps you because it appears that you have already replaced the Box. After I replaced the JB the switch problem went away.
Good Luck
Charlie
VN700 project bike 98% completed!!
68 Bushwhacker this winters project (in the works)
86 Honda GL1200i (winter project #2)
82 kz440 daily rider for now!
A few clowns short of a circus now aren't we?
bullwinkle is offline
post #8 of 15 (permalink) Old 08-17-2008, 10:33 AM
Kawika
davewex's Avatar
may not be related, but I know I've seen an issue where the bike lost power, but not 100% and after sort of jiggling the key (ignition switch) it went away...good luck!
LETS RIDE!! VROC# 26137
☠ Black Candy ☠ '07 Mean Streak 1600
☠ Blue Crush ☠ '95 VN750-A11
davewex is offline
post #9 of 15 (permalink) Old 08-17-2008, 01:48 PM
fergy's Avatar
Dianna, I believe this has to be a short probably caused by corrosion in the stop switch or the starter button or both. I can't think of any other situation that could cause this. I believe I would be pulling both apart and seeing what's going on in there... Cindy has played with the innerds of the start switch, causing me to open one up and shoot some photos once upon a time. I've never opened up the stop switch area that I can remember. I'll look through my stuff and see if I can make any sense of it...
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #10 of 15 (permalink) Old 08-17-2008, 02:11 PM
fergy's Avatar
In the right controls there is a common red wire that splits before the control and goes to both the stop switch and the starter switch. My gut feeling is that maybe this wire is causing the problem. Maybe it is broken at the split and only making it to the starter switch, giving power to the bike only when the starter button is pushed, then losing power when the button is released. It could also be broken off the post on the stop switch, or the stop switch is dirty and not making contact when it is in the RUN position.
This is all a theory, but it seems to make sense to me!
I also have a new right control that I can send you if you can't get yours to clean up and fly straight. Let me know!
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
