Rear Turn Signals - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 08-14-2008, 12:12 AM Thread Starter
Love My Baby
rubyrick's Avatar
Rear Turn Signals
Hey all. On my '05 750 the rear turn signals are not illuminating unless the turn signal is activated. The fronts are both illuminated all the time, and flash brightly when the turn signal is activated. Is this normal (doesn't seem right!) and what do I do to fix it if it isn't normal? Thanks in advance, everyone.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #2 of 11 (permalink) Old 08-14-2008, 12:48 AM
cm4cm5's Avatar
yes this normal...the rear turn signals only light up when activated. in some states its illegal to have amber running lights. you can get a kit to make them into ruuning lights..you'll have to change the bulb to red or you can change the lense to red.
Jeff Brooks
Owensboro KY
'94 Vulcan 750
cm4cm5 is offline
post #3 of 11 (permalink) Old 08-14-2008, 01:14 AM Thread Starter
Love My Baby
rubyrick's Avatar
Thanks for your reply, cm4cm5. Is there consensus on this? It seems odd to me that they would be off in the back but on in the front. I would want as much light as possible to keep me visible. What say you???
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
X
rubyrick is offline
post #4 of 11 (permalink) Old 08-14-2008, 01:22 AM
cm4cm5's Avatar
yea im sure eveyone will agree, when i get some extra cash, im planning on converting mine to the brake/turn/running lights.
Jeff Brooks
Owensboro KY
'94 Vulcan 750
cm4cm5 is offline
post #5 of 11 (permalink) Old 08-14-2008, 07:32 AM
Crobins365's Avatar
Absolutely correct. There are no rear running lights unless you convert them. I just got a kit to do that - it has two rings of LED red lights, which get glued onto the inside of the lens. Then there's a series of wires that hook the LEDs into the power and brake leads, plus a relay, I guess, that overrides the LEDs when you turn either signal on. AMAZING difference in visibility. But now I can't remember the company from which I bought the kit - a few other folks have done this, so maybe someone will pipe in?? Help??
C
Crobins365 is offline
post #6 of 11 (permalink) Old 08-14-2008, 07:56 AM
750Doug's Avatar
It's not really a consensus- the rear's are not suppose to be lit unless blinking. They are not running lights, they are just blinkers. The front's are both, running and blinking.
All bikes are like this, something about not interfering with seeing the brake/tail light. It's a manufacturer rule, not ours.
And lighting up as much as possible up front so others can see you coming.
750Doug is offline
post #7 of 11 (permalink) Old 08-14-2008, 08:07 AM
Crobins365's Avatar
"It's not a consensus. It's the law!" lol
C
post #8 of 11 (permalink) Old 08-14-2008, 07:43 PM Thread Starter
Love My Baby
rubyrick's Avatar
Thanks all. For a while I thought I messed something up when I installed my LED tail light panel. Now I'm looking for LED turn signals, dual intensity for up front, single intensity for rear. I certainly would be interested in the rear turns being red running/brake lights that turn off and blink amber for when the turns are activated.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
X
rubyrick is offline
post #9 of 11 (permalink) Old 08-14-2008, 08:36 PM
It is okay to have red turn signals at the rear. The rear running lights must be red.
post #10 of 11 (permalink) Old 08-14-2008, 08:39 PM
Crobins365's Avatar
http://www.cruisercustomizing.com/de...i_Vul can_750
Here's a link to the conversion kit that I bought (thanks to CCSpinner's recommendations). Easy to install and I feel much better having running lights in the back (those LEDs plus the CA LED lightboard and you can't miss me!).
C
