R/R & Stator woes - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 3Likes
post #1 of 15 (permalink) Old 03-25-2016, 11:45 AM Thread Starter
Tinkerer
Gaz73's Avatar
R/R & Stator woes
Hi all, only bought my vulcan last week, the previous owner said that he'd had the bike checked over by auto-spark and the R/R & Stator where both working 100%. I'd no reason to disbelieve him as I wasn't aware of faults on the vulcan until joining this forum.
Anyhow, the previous owner added Dominator style headlights and aftermarket indicators/flashers. I took the bike out for a spin on saturday and the headlight stopped working, never thought much of it at the time as the wiring looks ropey to say the least and I plan on putting the stock headlight back on.
Spockster mentioned that I should check the voltage output as the headlight is linked to one leg of the stator.
First opportunity I got was today, checked the voltage on the battery and it drops down to 9 -10 volts when the engine is revved, so it ain't charging when its running.
So I assume the the R/R is shot? I'm just really hoping the Stator isn't fubar'd to
I'll get out into the shed for a while tomorrow and have a look at the stator... I preparing for the worst, scrap stator and hoping for the best... a new R/R needed...
Nothing like being dropped in at the deep end
If anyone has any hints/tips/suggestions I'mm all ears
Gaz73 is offline
post #2 of 15 (permalink) Old 03-25-2016, 11:53 AM
What you need to do is test each component separately with a multimeter.
Do a search on here, we have docs for each under Electrical.
Quick Rundown on stator test: Test AC voltage between all 3 legs of the stator (2 at each time, you'll have to test 3 times to test them all). You'll want to see voltage the same across all the legs of the stator, as low as 20v idle and as high as 90v @ 5k rpm (want to see above 50v @ 5k rpm). If you notice one leg of the stator has way less power than the rest, the stator is shot. Also test continuity to ground, each leg should have NO continuity to ground, if it does, the stator is shot.
For the regulator: http://www.electrosport.com/technica...ting-guide.pdf
Edit: Also charge up the battery, maybe have it tested. A bad battery can mimic a bad charging system.
Thorn likes this.
post #3 of 15 (permalink) Old 03-25-2016, 12:21 PM Thread Starter
Tinkerer
Gaz73's Avatar
Cheers thtanner for the advice... I've got a new AGM battery to collect tomorrow. So i'll try that first, If it's still dropping voltage, I'll try the other tests. Thanks again, Gaz
Gaz73 is offline
post #4 of 15 (permalink) Old 03-25-2016, 12:52 PM
mikesutch's Avatar
Also, if there is a voltage draw or short somewhere, the headlight relay may not be closing. If the R/R, stator, and battery check out ok, check for a parasitic draw (amperage going through the battery circuit with the bike off and key out) or a short by the headlight. Sometimes the auxiliary line gets pinched in the fork stops..
Mosfet R/R and relocated
2 wire Mod for the 1986 harness
VN750.com grill cover
mikesutch is offline
post #5 of 15 (permalink) Old 03-25-2016, 02:07 PM Thread Starter
Tinkerer
Gaz73's Avatar
Cheers Mike, I'll give that all a try tomorrow.
I managed to collect my AGM battery and dropped it in. Voltage still dropping on a rev, although on the new battery its dropping from 14+ to 13.79 volts.
Hopefully have an hour or two to myself tomorrow and will get to the bottom of it, thanks for all the help guys.
Gaz73 is offline
post #6 of 15 (permalink) Old 03-25-2016, 05:50 PM
I agree that I wouldn't jump to assuming the worse. Follow the instructions. Could be a simple R&R or excessive load. Pull the fuses out for the non-essentials when testing.
RobertGary1 is offline
post #7 of 15 (permalink) Old 03-25-2016, 07:54 PM
https://www.vn750.com/forum/showthread.php?t=24093 read this as well
OleDirtyDoc is online now
post #8 of 15 (permalink) Old 03-26-2016, 02:38 AM Thread Starter
Tinkerer
Gaz73's Avatar
Cheers folks I'll go through everything and run the tests you suggest. Unfortunately I could write everything I know about motorcycle electrics on the back of a postage stamp lol.
Gaz73 is offline
post #9 of 15 (permalink) Old 03-26-2016, 10:49 AM Thread Starter
Tinkerer
Gaz73's Avatar
Didn't get the time in the shed as I hoped for, but got 10 minutes to myself and nipped out.
I put the voltmeter across the battery terminals first to see what the new AGM battery was like after being left in the bike overnight. 12.4v
I didn't have enough time to check the stator or R/R (fingers crossed tomorrow)
I forgot to mention that one of the 10amp fuses was blown yesterday, I replaced it and the headlight worked again (its a miracle lol), however after reading the about the blue wire in the JB I done that just now.
I started the bike up and on idle the battery was reading up to 13.57v on the voltmeter however when revved, she's dropping as low as 5.34v so quite a big drop compared to last nights test.
Anyway, tomorrow is another day and I'll check everything and report back
Man can not live by bread alone... he needs Duct tape & WD40
Gaz73 is offline
post #10 of 15 (permalink) Old 03-27-2016, 01:37 PM
5v when revved? Can't believe it stayed running! Wow
