Turn Signlas :/ - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 11 (permalink) Old 03-19-2016, 03:19 PM Thread Starter
Turn Signlas :/
Last season I replaced the rear turn signals with 2-wire bullets (they are not LED) and everything worked for a few months. Then the dash would show they were blinking but they were not. The front signals are stock.
Today I went to check it out and the front signals work as running lights, but none of the turn signals flash. The dash does not indicate flashing either.
Where do I start? The rear signals I replaced show continuity so there is a complete path...
94' Vulcan 750 39K
900 Classic Seat Mod
Bullet Rear Signals
VulcanRod is offline
post #2 of 11 (permalink) Old 03-19-2016, 04:55 PM
check/replace the flasher module.. 1st place I would start.
michiganteddybear is offline
post #3 of 11 (permalink) Old 03-19-2016, 05:04 PM Thread Starter
Alright Thanks, I've been looking on the forum, but where exactly is that relay located?
94' Vulcan 750 39K
Bullet Rear Signals
post #4 of 11 (permalink) Old 03-19-2016, 05:46 PM
If I remember it's under the seat
post #5 of 11 (permalink) Old 03-19-2016, 06:22 PM Thread Starter
Well now is a perfect time for me to find, working on a seat mod now as well
94' Vulcan 750 39K
Bullet Rear Signals
post #6 of 11 (permalink) Old 03-19-2016, 07:21 PM
under seat, back side of battery box if I recall.
post #7 of 11 (permalink) Old 03-19-2016, 08:18 PM Thread Starter
Yeah I found it Thank You all for the help. It looks as if it had a surge or could be cause of age, but it was cracked and bent pretty good. I'll have to look up the replacement, all info on side has been rubbed off.
94' Vulcan 750 39K
Bullet Rear Signals
post #8 of 11 (permalink) Old 03-19-2016, 09:42 PM
a cheap replacement is the EP34 (I think), its an all electronic one.. will directly replace the old bi-metal kind, and will work if you change to LED turnsignals, without any loading resistors needed
post #9 of 11 (permalink) Old 03-20-2016, 12:19 AM
Yup ep34
post #10 of 11 (permalink) Old 03-20-2016, 01:42 AM
x3 on ep34.
