Stator assembly bolt torque settings - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By Spockster
post #1 of 4 (permalink) Old 03-17-2016, 04:49 PM Thread Starter
AMH
Guys,
I installed my Stator and pickup coils but had a question on the torque Ft-lb to tighten the 3 stator assembly bolts. Clymer manual states 9 Ft-Lb and as I tight, it just feels like I'm tightening way more than I should, is that correct?
The manual shows :
9 ft-lb for the stator assembly bolts
92 ft-Lb for the Rotor Bolt
51 ft-LB for the balancer bolt
For the alternator cover, to tighten the 10 bolts in a cross pattern but it doesn't specify any torque settings.
I appreciate any info you can provide!
AMH is offline
post #2 of 4 (permalink) Old 03-17-2016, 06:12 PM
I'd go by those numbers. Cover bolts I always just went by feel.
Steel bolts going into steel threads you have some room for error. But steel bolts going into aluminum threads you don't want to push it.
You use loctite on those stator bolts?
post #3 of 4 (permalink) Old 03-17-2016, 07:00 PM
Seems like those stator screws were fairly small, 9 ft/lbs seems like a lot. I didn't torque mine, just used my calibrated wrist. May have dabbed Loctite on them, since I used it on the balancer bolt. I do remember they were really tight when I took them out.
edit: Was also using 1/4" drive ratchet.
The balancer and rotor bolts were the only ones I torqued.
Would be tough if that's a misprint and it's supposed to 9 in/lbs.
Check the torque chart here, in a sticky post, pretty sure there is info on torque spec by thread size. That's what we go by if we don't know the torque value on something.
edit: The chart is here: https://www.vn750.com/forum/11-vn750-...-values-2.html
The two sizes below from that list are in inch/lbs. There's a converter online to calculate in/lb to ft/lb. http://www.unitconversion.org/energy...onversion.html
5 mm = 30- 34 in-lb* (> 3/16") converts to 2.5 - 2.8 ft/lbs
6 mm = 52- 69 in-lb* (< 1/4") converts to 4.3 - 5.7 ft/lbs
Thorn likes this.
post #4 of 4 (permalink) Old 03-21-2016, 12:16 PM Thread Starter
AMH
Thank you guys....I did use the loctite on the stator assembly bolts and looked at the Kawasaki manual and Clymer and they both state ( 12-NM , 104 in-Lb) . So, I divide 104 by 12 and I get 8.66 ft-lb. So, I'm close!
AMH is offline
