Batteries-Plus Xtreme Batteries - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 08-12-2008, 02:19 PM Thread Starter
Joem's Avatar
Question Batteries-Plus Xtreme Batteries
Do any of you have good or bad experience with Batteries-Plus Xtreme Batteries? I am trying to find a replacement locally, but none of the local shops carry the Yuasa or Westco batteries in stock. Batteries-Plus says their Sealed AGM Xtreme brand is comperable, it's cheaper, has a longer warranty and they have one in stock.
Joe McAdoo
Springfield, MO
[email protected]
VROC # 28175
Joem is offline
post #2 of 8 (permalink) Old 08-12-2008, 02:30 PM
ExNewbie..Still Learnin'!
rsawyer's Avatar
Sears has a great battery as well. Roughly $80. 14AHS-BL
'89 Vulcan 750
VROC# 30232
HID Headlamp Conversion
V&H Cruzers (great sound)
Kaw V-Force Windshield
Kaw Rear Luggage Rack
Kaw Engine Guard
VN750.COM Grill Cover
W&M Black Magic Saddlebags
Diehard M/F Battery
R/R Replaced/Relocated
Stator Replaced
Voltmeter Installed
Splines Lubed
Metzler 880 Marathons
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
Fuel Tank Derusted/Lined/Sealed
NGK Iridium Plugs
rsawyer is offline
post #3 of 8 (permalink) Old 08-12-2008, 03:25 PM
93VN750's Avatar
I have one and my buddy has one, year and a half later, still no problems.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #4 of 8 (permalink) Old 08-12-2008, 09:10 PM
85 VN 700
curtis97322's Avatar
I had one and killed it in less than 6 months... Though I do ride more than most...
Happy with my 2 month old diehard (yusa), wish I'd never bothered with the batteries plus battery (which they claimed was still good since it was still under warranty - I'll never buy another battery from the bastards and I'd recommend you not).
Curtis - Albany Oregon.
Ammo Can Saddlebags
Hit the 24k mile July 2008
curtis97322 is offline
post #5 of 8 (permalink) Old 08-14-2008, 01:37 PM
Now what
Ironman's Avatar
Funny you should ask. I've had one since May and don't like it. It starts the bike, but not as well as the DieHard did. The starter turns slower and it takes longer for the bike to start. I have problems with backfiring on cold starts (never had that problem before). If you can't find a DieHard, Yuasa (same thing) or a Westco locally, order the Westco on line. Pricey, but shipping is included and will start the bike reliably. http://tinyurl.com/5fmmqs
The DieHards are on sale through the 16th http://tinyurl.com/55x6mg
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #6 of 8 (permalink) Old 08-17-2008, 12:46 PM
MANIC MECHANIC
vulcanjoe's Avatar
I have the batteries plus battery now and have had it for over a year with no problems .
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #7 of 8 (permalink) Old 08-17-2008, 06:44 PM
Sky Rider's Avatar
I bought the Wal Mart version last January and have had no issues with it at all. The polarity was reversed (pos on neg side, etc) so just turned the battery 180 and hooked her up. Wires aren't stretched or anything so no mods needed.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #8 of 8 (permalink) Old 08-17-2008, 09:17 PM
85 VN 700
Exactly what was happening with my bike. Worked well for a bit, then started being an ass. Replaced the battery even though it might have been considered "good" by a shop. The diehard makes the bike behave like a completely different (in a good way) animal.
Ammo Can Saddlebags
