Headlight Lens Question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 08-12-2008, 02:13 PM Thread Starter
ChrisC's Avatar
There's all kinds of info out here regarding the bulb, but I can't find anything on the lens. Is the lens a standard 7"? I'm looking to upgrade to a Cibie or Hella E-code 7" headlamp. Has anyone else replaced the stock lens?
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-De-Goated/Re-goated
-Coastered
-Splines Lubed
-Stebel Nautilus Horn
-AutoMeter 2" VOM
-Silverstar Headlight
-Plexifairing III
ChrisC is offline
post #2 of 20 (permalink) Old 08-12-2008, 02:19 PM
I am with you here. I have never been able to tell what size this lens is.
post #3 of 20 (permalink) Old 08-12-2008, 02:35 PM
ExNewbie..Still Learnin'!
rsawyer's Avatar
I'd like to know as well. Mine's starting to get just a little "cloudy". Is the normal for these at 20 years old?
'89 Vulcan 750
VROC# 30232
HID Headlamp Conversion
V&H Cruzers (great sound)
Kaw V-Force Windshield
Kaw Rear Luggage Rack
Kaw Engine Guard
VN750.COM Grill Cover
W&M Black Magic Saddlebags
Diehard M/F Battery
R/R Replaced/Relocated
Stator Replaced
Voltmeter Installed
Splines Lubed
Metzler 880 Marathons
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
Fuel Tank Derusted/Lined/Sealed
NGK Iridium Plugs
rsawyer is offline
post #4 of 20 (permalink) Old 08-12-2008, 03:30 PM
I think it was Dianna who changed lenses, but needed to also change out the headlight bucket. I think because of clearance issues.
post #5 of 20 (permalink) Old 08-12-2008, 05:04 PM
750Doug's Avatar
I just walked outside and measured mine and it's just shy of 6.5", which (I think) is what's referred to a 7".
750Doug is offline
post #6 of 20 (permalink) Old 08-12-2008, 05:39 PM
Yes, it is called a "7 inch headlamp"...as mentioned, Dianna did switch to a diffrent reflector (that is what I call them) but had to switch to a diffrent headlight bucket because the Kawasaki one is not long enough to fit the aftermarket reflectors. I think she used one off an old Suzuki.
A trip to a junk yard would be your first move then........
post #7 of 20 (permalink) Old 08-12-2008, 05:54 PM
fergy's Avatar
A while back, I ordered a new lense/reflector, a 7" just to try it. It was too wide in diameter for the ring to go around it off our bikes. So I know the width is weird.
If anyone has done any headlight mods that worked out good, I'd sure like to know about them, and see some photos! I'd like to get more light up front without taxing the electrical system.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #8 of 20 (permalink) Old 08-12-2008, 08:12 PM
Check out Gypsy's defunct website, I beleive she did a lens change. Search Gypsy and there is a link to her archieve.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #9 of 20 (permalink) Old 08-13-2008, 12:28 AM
dirtrack650's Avatar
It can be done, I've done it on other bikes that used a standard 7" motorcycle headlamp. I did have to cut a hole in the back of the HL bucket for the extra depth. My plan is to use a 'free form crystal lens' - nearly clear with a cool looking reflector - similar to HID when using the silverstar bulb, but w/o the high price.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #10 of 20 (permalink) Old 08-13-2008, 12:46 PM Thread Starter
ChrisC's Avatar
This is probably a dumb question, so be gentile, but, is there a difference between a 7" motorcycle headlight and a 7" auto headlight?
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-Coastered
-Splines Lubed
-AutoMeter 2" VOM
-Plexifairing III
ChrisC is offline
