R.P.M. Readings = Voltage Readings - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 08-11-2008, 08:26 PM Thread Starter
I took a suggestion and took voltage readings a differant R.P.M.
Here are the results to see if I have a charging Electrical System
I have a 1995 VN730A11
2000 RPM= 11.94 Volts
3000 RPM= 11.95 Volts
4000 RPM=11.97 Volts
5000 RPM= 11.98 Volts
6000 RPM= 11.99 Volts
Any Suggenstion as to how my charging system is doing???
I also went toAutoZone and bought a new Battery... The kind that you need to fill it up with the Acid provided and put in the hole plug strip. strip
Thanks all
asantacruz is offline
post #2 of 12 (permalink) Old 08-11-2008, 08:52 PM
Something there is not working. U have a problem.
post #3 of 12 (permalink) Old 08-11-2008, 09:02 PM
Love My Baby
rubyrick's Avatar
I confirm, you do not have a charging electrical system. A new MF battery will be great, but you need to check your r/r and stator, too. It could just be that the battery won't take a charge, but it could be that the system isn't charging, too. Hate to see you buy a new bat and have the same problems.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #4 of 12 (permalink) Old 08-11-2008, 09:16 PM Thread Starter
What is a R/R
post #5 of 12 (permalink) Old 08-11-2008, 09:55 PM
Originally Posted by asantacruz View Post
What is a R/R
Regulator/Rectifier
It's what changes the stator volts from AC to DC and limits the amount of charge going into the battery.
As for the battery..... does it have the vent tube that must be attached, or is it vent tube free?
Some maintenance free batteries need filled when first purchased, but aren't wet cell's (as long as there's no vent tube).
Have the battery (whatever kind it is) load tested at an auto parts store.
post #6 of 12 (permalink) Old 08-12-2008, 12:39 AM
Sky Rider's Avatar
If you had to add the electrolyte to the battery, you will need to charge it before you use it to get the maximum out of it. A slow charge is better than a fast charge and the charge rate shouldn't be above 2 amps.
I agree with the rest here that you may have a fried R/R. Check the stator too as once the R/R goes, it usually takes the stator with it.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #7 of 12 (permalink) Old 08-12-2008, 08:31 PM Thread Starter
Thanks for your help.
post #8 of 12 (permalink) Old 08-12-2008, 08:31 PM Thread Starter
Thanks for your advice, will work on it.
post #9 of 12 (permalink) Old 08-12-2008, 08:32 PM Thread Starter
Will check them out and thanks.
post #10 of 12 (permalink) Old 08-12-2008, 08:33 PM Thread Starter
Thanks
