lighting system questions - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 1 (permalink) Old 08-11-2008, 01:33 PM Thread Starter
pro skateboarder
yoshiaka13's Avatar
hey all. so as some of you all know I have been hunting down my elusive charging system problem. so far everything has been checking out fine, but the other day on a whim I decided to check my readings with the headlight fuse out and then the tail light fuse out. right now at 5000rpms I'm reading 12.5v-12.7v... however I take out the fuse for the headlight it climbs to 13.8v-14.1v.. same thing when I put the headlight fuse back and take out the tail light fuse. is this normal? or should I look into this a little further. its hard to believe either one of these circuits are using a little over a volt each! ideas anyone..insight? thanks.
1990 VN750
(Full Throttle to the Funeral)
or if i have to donate blood for money for the stator ill change the name to(blood sweat and tears)
Cobra pipes
Vanard vision LED engine lights and ground effects
Mustang seat
custom paint (black w/blue metallic flake)
saddlebags
tool bag
skull hand grips
custom painted engine. (black w/bare aluminum)
maltese cross tail light
highway pegs
bigger fuel tank.
yoshiaka13 is offline
