R/R relocation bracket - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 08-08-2008, 06:05 PM Thread Starter
Hi All,
I'm going to make a bracket out of thick sheet metal, similar to the one Bulldog makes. Does this fit between the foot peg and frame, and if so, how does this affect the way the foot peg fits on the frame?
Thanks,
Rick
rhlee is offline
post #2 of 6 (permalink) Old 08-08-2008, 10:05 PM
That's the way I mounted my bracket. I used a piece of approximately 0.09" thick stock I had hanging around. The footpeg is not affected to much by the thickness.
Glenn Douglas
Londonderry, NH
GDouglas is offline
post #3 of 6 (permalink) Old 08-08-2008, 10:49 PM
dirtrack650's Avatar
Suggestion to rubber mount it. It's previous location was attached to the bottom of a heavy object (battery) and the new location most of us use my introduce more vibes that before. I just used some thick rubber washers, worked great.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #4 of 6 (permalink) Old 08-28-2008, 11:00 AM
so the case itself is not required to be attached directly to the metal frame ?
Thanks
nikos is offline
post #5 of 6 (permalink) Old 08-28-2008, 10:59 PM
VulcanRider08's Avatar
OK...UNCLE...what does R/R stand for?
2003 VN750 "Vulberry"
Panama City, FL
VulcanRider08 is offline
post #6 of 6 (permalink) Old 08-29-2008, 12:21 AM
On His Lady Vulcan
wkrizan's Avatar
Regulator/Rectifier
Pictures of the "Ladies"
wkrizan is offline
