battery dead - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 08-04-2008, 06:41 PM Thread Starter
battery dead
I seem to have an intermittent battery problem. The battery went dead a couple of weeks ago, I figured something got wet because I forgot to put the cover on during a heavy downfall. I hooked it up to my trickle charger and drove a few times since. I drove it yesterday after it sat for about 4 days and it started fine. This morning I went to start it and it cranked but no start, then nothing. Any suggestions
lennyb3us is offline
post #2 of 7 (permalink) Old 08-04-2008, 09:01 PM
First suggestion would be to get the battery load tested. Next would be a question....Is it a maintenance free battery??
post #3 of 7 (permalink) Old 08-04-2008, 09:26 PM
Love My Baby
rubyrick's Avatar
Hey Lenny. Glad you posted here. Do yourself a favor and get a new maintenance free battery from Sears or from one of the reputable online battery stores. You can do a search here on this site and find the recommended batteries. But I would suggest you stick with Yuasa if you can afford it or DieHard if there's a Sears nearby. DEFINITELY MAINTENANCE FREE.
Now, if you already have a MF battery and it's not even close to two years old yet, you might be able to save it and it might still last a year or two. Listen to Hyperbuzzin and get it load tested. Autozone won't load test motorcycle batteries in my area because their load testers can blow up a small battery. Sears might.
Good luck. I went through this too, and I replaced my bat with another wet cell and it only lasted 9 months. Then I got a Sears MF bat and it has made a world of difference.
Let us know how you do...
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #4 of 7 (permalink) Old 08-05-2008, 05:54 AM Thread Starter
Thanks for the advice. One more queation crosses my mind. Grnated this is something I would do to test the generator on a car but I figured the principle is the same. The battery I believe is th initial charge to start the bike then it runs on the generator correct? If that is the case once the bike is running I should be able to disconnect the battery and the bike would still run.Any one have any thoughts.
post #5 of 7 (permalink) Old 08-05-2008, 08:32 AM
No, I believe the battery needs to be connected, and have a good charge going to it, for the bike to run.
post #6 of 7 (permalink) Old 08-05-2008, 02:59 PM
the way the electrical system is wired...the bike may or may not stay runing. The R/R requires a signal voltage from the battery. if you disconnect the battery, the referance signal is gone, and it will either overcharge or it won't charge at all...either case...not good.
Best way to test to see if the charging system is to take voltage readings off of the battery at Idel, 2000 rpm, 4000 rpm, and 5-6000 rpm. then match these number to the clymers manual. or post your resaults here and we can give more advice on what to check now....but first I would replace that battery.
post #7 of 7 (permalink) Old 08-11-2008, 10:05 AM
ExNewbie..Still Learnin'!
rsawyer's Avatar
Highly recommend the M/F battery suggested by those above. Just replaced mine this weekend with a Diehard (would bet it's secretly made for Sears by Yuasa) after getting stuck at the store with the infamous "hot - won't start" problem and having to jump start in a parking lot full of people.
Hard to impress the ladies while you sit swearing under your breath at your lifeless machine. They don't believe the "but it's never happened before" excuse either!
World of difference in KNOWING that it'll start strongly after sitting for a few minutes instead of it being a coin flip.
'89 Vulcan 750
VROC# 30232
HID Headlamp Conversion
V&H Cruzers (great sound)
Kaw V-Force Windshield
Kaw Rear Luggage Rack
Kaw Engine Guard
VN750.COM Grill Cover
W&M Black Magic Saddlebags
Diehard M/F Battery
R/R Replaced/Relocated
Stator Replaced
Voltmeter Installed
Splines Lubed
Metzler 880 Marathons
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
Fuel Tank Derusted/Lined/Sealed
NGK Iridium Plugs
rsawyer is offline
