headlight wires?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 08-03-2008, 11:21 PM Thread Starter
headlight wires??
ok so today i did the old take off the gauges and paint them cuz they rust like crazy.... they now look sharp as H*LL... but anyway i had the headlight out andi noticed there were two wires with those U connectors on the end.... im assuming that thats how you wire a light bar onto it?? could be wrong so thats why im asking.... thanks again..
bigrepp61 is offline
post #2 of 15 (permalink) Old 08-04-2008, 12:34 AM
HAWK
Ccspinner's Avatar
Those are hook up's for accessories, I may be mistaken but they are not switched.
What ever you hook up there will be on all the time unless you put a switch in line.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 15 (permalink) Old 08-04-2008, 08:06 AM
Sounds right to me.
Also, be aware that you don't want to use a lightbar that's too powerful (over 30 watts per light).
post #4 of 15 (permalink) Old 08-04-2008, 10:32 AM Thread Starter
ok good... yeah i just saw them hanging there and wanted to make sure i didnt knock them loose or anytthing,.... thanks..
post #5 of 15 (permalink) Old 08-04-2008, 12:37 PM
yes these wires are unswitched acc wires...
post #6 of 15 (permalink) Old 08-04-2008, 12:41 PM
Scootergptx's Avatar
Good to know about the wires. Gonna fab up a mount for the radar detector that's in my truck. Nice stretch of road by the house I keep finding myself going a bit over the speed limit.
Scootergptx is offline
post #7 of 15 (permalink) Old 08-04-2008, 01:12 PM
I used a relay. I came dirrectly off of the bat for the lights. I activate the relay from the high beam side of the lights. I also have a switch to cut the lights off when not needed.
I have two 35 watt bulbs (the lowest I could find), they do better with the electic system than the original 50 watts did.
post #8 of 15 (permalink) Old 08-04-2008, 03:27 PM Thread Starter
now heres a good question for you guys....are those wires also on a relay or sumthin like the other headlight wires or should i hook them up to a relay so i dont short out the bike in the case i decide to hook up some illegal lighting in the future.... my fiancee wants to paint her bike a metalic emarld green (close to the honda vtx 1300c and 1800 c) and i think i might install some neon LED's after that to kick it up a notch... nice and non legal the way i like it!!! hahaha.... i will end up putting a switch but if they are hooked up to power already and i dont forsee a lightbar in the near future i think thats the way im going to go...
post #9 of 15 (permalink) Old 08-04-2008, 04:09 PM
ChrisC's Avatar
No relays; no switches. There are 2 sets of acc lugs on the bike. One set in the headlight bucket, and on set behind the right side cover near the RLU and starter solenoid. Both come straight off of the 10A fuse in the JB (3a and 3b on the 8-pin connector; White/Blue wire).
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-De-Goated/Re-goated
-Coastered
-Splines Lubed
-Stebel Nautilus Horn
-AutoMeter 2" VOM
-Silverstar Headlight
-Plexifairing III
ChrisC is offline
post #10 of 15 (permalink) Old 08-04-2008, 05:19 PM
ExNewbie..Still Learnin'!
rsawyer's Avatar
Bigg - The "paint the gauges" maintenance item was mistakenly left out of the manual but mine sure needs it. How did you do it and/or what should I definitely NOT do? Realize it's not electrical related but hadn't seen it mentioned specifically elsewhere. If it is, would someone kindly direct me in the right direction in the Forum?
'89 Vulcan 750
VROC# 30232
HID Headlamp Conversion
V&H Cruzers (great sound)
Kaw V-Force Windshield
Kaw Rear Luggage Rack
Kaw Engine Guard
VN750.COM Grill Cover
W&M Black Magic Saddlebags
Diehard M/F Battery
R/R Replaced/Relocated
Stator Replaced
Voltmeter Installed
Splines Lubed
Metzler 880 Marathons
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
Fuel Tank Derusted/Lined/Sealed
NGK Iridium Plugs
rsawyer is offline
