no bezel lights - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 08-03-2008, 12:45 AM Thread Starter
99vulcan750's Avatar
no bezel lights
I went to a friends house tonight. everything was working fine to my knowledge... I get ready to leave around 11 and the meters and fuel gauge aren't lit up.. before i tear apart the dash, what should i be looking for tomorrow when I do this? I am guessign a short or a disconnect somewhere as the turn indicators and high beam indicator works...
'99 VN750 with 8900 miles and growing (3,111 when I bought it 03-22-08)
Ear shave with Unipods
Drilled mufflers and degoat
TOC springs
N/C Street shield EX windshield
Jumbo Saddleman Highway Studded saddlebags
Willie and Max Saddlebag mounting kit
License plate turn signals
Home made sissy bar
Luggage Rack from Scoop
http://youtube.com/user/99vulcan750
99vulcan750 is offline
post #2 of 8 (permalink) Old 08-03-2008, 03:44 AM
Did you have running lights?
Check the connectors inside the headlight housing...I bet the blue wire is unplugged...you might also have a burned out bulb, Check the bulb first.
post #3 of 8 (permalink) Old 08-03-2008, 08:57 AM
Crobins365's Avatar
Each "item" on the gauges has its own bulb, so I don't think it could be that. But definitely check the connection for the gauge cluster - and when you put it back together (says I, anticipating that's the prob), make sure you've cleaned out the pins and added a little dielectric grease to improve conductivity.
C
Crobins365 is offline
post #4 of 8 (permalink) Old 08-04-2008, 01:23 PM
yes cindy, they each have thier own bulb, but they are wired like old chrismastree lights...where one burns out they all go out.
post #5 of 8 (permalink) Old 08-04-2008, 01:52 PM Thread Starter
don't you hate it when that happens?
Right now, the bike doesn't have any tires- it's just resting on it's forks and the center stand... I am bringing them in to be replaced, and balanced. $60 all said and done.. I am also lubing the splines! it's an easy process to remove the rear tire if you have the front tire off!
I will let you all know what is happening with the lights when I get back from taking care of the tires.. I can always grab a small battery powered clamp light for the bezels if I need to drive in the dark...
TOC springs
Home made sissy bar
post #6 of 8 (permalink) Old 08-04-2008, 02:18 PM
Chucklehead
dragon159's Avatar
I'll be the one to bite ... I assume you checked the fuse. I had this problem too right after getting the bike. A worn wire off the key switch would short out and knock out all the lights, bike would run fine, headlight worked too, but no running lights.
You can tell me to go shut up now lol.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #7 of 8 (permalink) Old 08-08-2008, 08:13 PM Thread Starter
now I feel stupid.. it was the 10Amp fuse...
TOC springs
Home made sissy bar
post #8 of 8 (permalink) Old 08-13-2008, 07:14 PM
good job....I "Assumed" that you had already checked the fuse...that is always the first place to start any troubleshooting.
