Electrical Short Somewhere - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 01-10-2016, 02:47 PM Thread Starter
DR.BADNEWS's Avatar
I did the two-wire mod and replaced the R/R and now I'm shorting out a black wire with a yellow stripe leading under the gas tank to a connection along with a white wire with yellow stripe from the wiring harness.
The insulation melted and caught on fire when I tried to start the bike which did not avail.
DR.BADNEWS is offline
post #2 of 6 (permalink) Old 01-10-2016, 03:05 PM
Is it the wires that go to the fuel sender off the gas tank?check the ground wire off the battery
post #3 of 6 (permalink) Old 01-10-2016, 04:53 PM
Looked at my bike and the wires for the fuel sender are black and yellow and white and yellow. Mine had a broken ground wire off the battery.would melt the wire when I pressed the start button. If I unplugged it it wouldn't turn over at all. These bikes have a complicated wiring harness and must be grounded properly
post #4 of 6 (permalink) Old 01-10-2016, 09:23 PM
And, most of the ground wires on the bike are black/yellow
michiganteddybear is offline
post #5 of 6 (permalink) Old 01-10-2016, 11:02 PM Thread Starter
DR.BADNEWS's Avatar
Yep, the ground wire off the battery to the frame was loose... What a shame this all would happen because of that.
post #6 of 6 (permalink) Old 01-10-2016, 11:36 PM
Happened to me on one of my MC's runs.stripped all the covering offa the wire harness before I found it.
