How hot does the R/R run? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 08-01-2008, 10:44 AM Thread Starter
dirtrack650's Avatar
I recently checked, cleaned, dielectric greased the three stator wires that plug together behind the motor and the result is 14.5 to 14.8 volts at the MF battery and a hotter r/r. My thought is more current is flowing (the plugs were in poor shape) so the r/r is hotter, but how hot is a normally running r/r? I checked the verses, Clymer, and called the local Kawa dealer (not help there except bring it in and we'll check it for $$$).
Thanks all...
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #2 of 14 (permalink) Old 08-01-2008, 11:58 AM
ChrisC's Avatar
I've never seen a rating for the temp of the RR. I imagine that the different manufacturers will have different temps. I have a Rick's RR, I'll try to get a temp reading off of it tonight after I drive home.
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-De-Goated/Re-goated
-Coastered
-Splines Lubed
-Stebel Nautilus Horn
-AutoMeter 2" VOM
-Silverstar Headlight
-Plexifairing III
ChrisC is offline
post #3 of 14 (permalink) Old 08-01-2008, 04:00 PM
Sky Rider's Avatar
Mine gets quite toasty after just a few minutes of running. Not too hot to touch but darn close.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #4 of 14 (permalink) Old 08-01-2008, 04:18 PM
They can get quite hot. I think we had a member hookup a thermocuple with a temp gauge and got it up to 150 degrees F. That would be too hot to touch for more than a few seconds.. BTW.
post #5 of 14 (permalink) Old 08-01-2008, 05:39 PM
750Doug's Avatar
Anybody have one of those digital, laser thermometer's?
750Doug is offline
post #6 of 14 (permalink) Old 08-01-2008, 06:27 PM Thread Starter
Ouch!
Seems that my connection was not passing much current to the R/R. This is a good description of the heat Sky Rider, thanks. I was surprised with the smallness of the wires too. What are they? 16 or 18 gauge? Anyone replace them with 14 gauge (I know about the fusing and I think I'll do that this winter).
Thanks KM, I have a cooling fan from a computer processor that would mount to the R/R fins, think that would have a effect? 150 would burn the hand quite easily.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #7 of 14 (permalink) Old 08-01-2008, 06:32 PM
Chucklehead
dragon159's Avatar
I do, but with my bike not running I wouldn't be able to check. If anyone is running up this way I'll have it at home, too bad I'm not online there. But Ccspinner has my number.
Gee I'm not alot of help.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #8 of 14 (permalink) Old 08-01-2008, 08:18 PM
Originally Posted by dirtrack650 View Post
.. I have a cooling fan from a computer processor that would mount to the R/R fins, think that would have a effect? ....
This was proposed a few years back, and one of our engineers figured that the energy needed to run the fan would only offset the amount of heat it caused , and would not cool off the R/R more than just moving it from out under the battery box and relocating by the passenger peg (as so many do now)
Hard to find a computer fan that puts out 30-75 mph air. When the bike is stopped at a light, the first sentance would be the case, the fan would just barely cool the R/R , while it was just adding more strain to the electrical system. (You'd be better off keeping a bottle of water with you and squirting some on the unit while waiting for the light to change)
Do understand that these things are supposed to get hot, this was a factor in their design. But many feel that the stock placement -inside the bike and right above part of the exhaust system- added more heat than the original design calculated for.
I have always felt that many get a bit too paranoid about this item, but it does make "good logic" to move them where they can get a better flow of air.
Unless you have a pretty big motor on a fan, your not going to match the amount of air you get by simply riding the bike.
post #9 of 14 (permalink) Old 08-02-2008, 02:45 AM
another thaught on a computer fan....they run on 1.5 or 5 volts...are bikes range between 12 and 14.5 v way too much for the small fans..
post #10 of 14 (permalink) Old 08-02-2008, 10:44 AM
darrelc5's Avatar
The stator leads are very small and the fact that they get hot during operation testifies to their high resistance under load. I have not measured the voltage drop over the 16 inches (or so) of lead, but I measured the wire size when I replaced it all and decided it was 18 AWG. I replaced the stator leads with Teflon coated 14 AWG wire when I replaced the stator and used 12 AWG for the R/R output and ground leads and they run cool now. The R/R itself (relocated) still gets pretty toasty.
Darrel
'03 Vulcan 750 (90k miles)
-Corbin Seat
-V-Force Windshield
-LeatherLyke Touring Bags
-Chrome Luggage Rack
-Headlight Modulator
-Brakelight Flasher
-MF Battery
-Heads-Up Voltage Monitor
-Replaced Stator (9,000 and 16,000 mi.)
-Oil-cooled Stator Mod (photos)
-Replaced and Relocated R/R
-Greased rear splines
-Fused Stator (photos)
-Metzeler ME880 Marathon 170/80-15 (Rear), 110/90-19 (Front)
-TOC MCCTs installed
-Headlight Relays
SOLD - 2013
darrelc5 is offline
