Bike just died again... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 22 (permalink) Old 12-10-2015, 06:34 PM Thread Starter
DR.BADNEWS's Avatar
Second time in 2 months, but my bike died on me again. This time while I was riding. I was using it all day at highway speeds mostly, and when I was on my way home it died at a stop light 2 miles from my home coming back from selling my other bike. Just replaced the battery a couple months ago. Bike just hit 12,000 miles and allegedly already had the stator replaced. I'm gonna check voltage at the battery terminals when I get home, but for now I need to jump it or something to get it home.
How do I test the stator? And is there anything I should check first?
DR.BADNEWS is offline
post #2 of 22 (permalink) Old 12-10-2015, 06:39 PM
Look at the stickies here in the electrical section and read the Vulcan verses
OleDirtyDoc is online now
post #3 of 22 (permalink) Old 12-10-2015, 07:35 PM
93VN750's Avatar
Just as a quick check, measure the voltage on the battery when off, at idle, then 3K rpm see what you get. If the voltage is not higher at 3K rpm, you've got a problem.
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #4 of 22 (permalink) Old 12-11-2015, 07:53 AM
Does it just shut off instantaneously? Have you cleaned the ignition switch?
post #5 of 22 (permalink) Old 12-12-2015, 03:10 PM Thread Starter
DR.BADNEWS's Avatar
I've sprayed contact cleaner into the ignition switch. The first symptom was the headlight turned off while riding, then loss of power, then it died idling at a stop light. Wouldn't turn back on until 30 minutes later and the headlight still wouldn't come on. Gotta charge it to get it started again. Been busy thought lately because my house was just robbed later that night. It's been a **** fest.
Can anyone link me to the best replacement stator and R/R? I guess that's my next move.
post #6 of 22 (permalink) Old 12-12-2015, 07:43 PM
Both of these are considered the best bet.
Tim Parrot (for stator rewind)
Rebuild Services by Tim Parrott - Rebuilder**of stators , field rotors, starters , New Regulators
MOSFET r/r kit:
Universal FH020AA Kit with Maxifuse or 30 amp Circuit breaker.
(scroll down) >>---> Home
There's an r/r kit on ebay too.
Shindengen MOSFET FH020AA Regulator Rectifier Kit Replaces FH012AA | eBay
Easy MOSFET Wiring - http://roadstercycle.com/Easy%20Mosfet%20Install.htm
post #7 of 22 (permalink) Old 12-13-2015, 12:26 PM Thread Starter
DR.BADNEWS's Avatar
What's everyone's thoughts on Caltric? Anyone have any experience with this combo from Amazon?
Caltric STATOR & REGULATOR RECTIFIER Fits KAWASAKI VN750 VULCAN 750 1986-2006 MOTORCYCLE https://www.amazon.com/dp/B009YXF5A4..._KOzBwb76N50HZ
Literally first result and seems most convenient. Price is manageable if the product is quality. But I hope it's not too good to be true and fails quickly.
I just want it to work for another 6 months at most then sell the bike.
post #8 of 22 (permalink) Old 12-13-2015, 12:35 PM
Not even for a week, unless changing stators is more fun than I remember.
post #9 of 22 (permalink) Old 12-13-2015, 12:46 PM
Please don't buy a crappy stator and then sell the bike. That's not nice!
post #10 of 22 (permalink) Old 12-13-2015, 03:46 PM Thread Starter
DR.BADNEWS's Avatar
You mean the stator won't last a week, or what do you mean...?
