Spark plug wire - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 12-10-2015, 05:36 AM Thread Starter
Spark plug wire
Ok I was talking to a guy who increased his spark plug wires from 7mm to 8mm. Is it possible to just replace the wires and not ends assembly that goes on the ends that connect to the spark plug? If so, how do I get the ends off the wires?
mrseedsower is offline
post #2 of 16 (permalink) Old 12-10-2015, 08:05 AM
calebj's Avatar
This should have the info you need:
https://www.vn750.com/forum/19-electr....html#post3101
1986 VN750 27k miles
1999 EN500 32k
1983 GL650i in pieces. Someday it will ride again.
calebj is offline
post #3 of 16 (permalink) Old 12-10-2015, 01:43 PM
the ends twist off the wires, but 8mm wires need 8mm spark plug ends, or you have to shave insulation off the wires to get the 7mm boots to fit the 8mm wire.
post #4 of 16 (permalink) Old 01-04-2016, 08:18 AM
calebj's Avatar
I have a spool of 8mm Accel wire as well as the cheap replacement wire from Dennis Kirk. It was no trouble at all to get the 8mm wire into the NGK plug ends, but I couldn't get it into the stock coil side retainers at all. I used the DK wire temporarily, but would like to use the 8mm wire since I've got it and it appears to be much higher quality than the generic DK wire. Can anybody that's used 8mm wire comment on how they got around that?
1999 EN500 32k
calebj is offline
post #5 of 16 (permalink) Old 01-04-2016, 09:57 AM
Could trim rubber insulation a little off the end of wire?
OleDirtyDoc is online now
post #6 of 16 (permalink) Old 01-04-2016, 10:01 AM
calebj's Avatar
I tried that, but removing the rubber insulation makes it far too thin. I didn't see an easy way to remove just a little bit of insulation. Basically an all or nothing thing. I'd love to be wrong about that, though.
1999 EN500 32k
calebj is offline
post #7 of 16 (permalink) Old 01-04-2016, 10:43 AM
I switched to 8mm years ago. All I did was use my table top grinding wheel to evenly shave off the excess sheathing till it fit the stock coil.
Also, no problem with the NGK caps.
Since sold them to Wib when I stripped the bike.
post #8 of 16 (permalink) Old 01-04-2016, 10:52 AM
calebj's Avatar
So you just held it up to a bench grinder? That could work. Definitely an option I hadn't considered.
1999 EN500 32k
calebj is offline
post #9 of 16 (permalink) Old 01-04-2016, 12:16 PM
Better than my idea. Pocket knife.
post #10 of 16 (permalink) Old 01-04-2016, 01:06 PM
calebj's Avatar
Yeah, the knife was my first try and an utter failure. Thankfully I have 75 feet to work with so burning an inch or so as scrap wasn't a tremendous loss.
1999 EN500 32k
calebj is offline
